Re: cat. converter delete on a 2008 dully with a 6.7
[Re: tjmarcus1]
#1512214
10/04/13 04:31 PM
10/04/13 04:31 PM
Posts: 34,958 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Are you asking about DPF delete on a diesel ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: dusturbd340W5]
#1512219
10/05/13 01:25 PM
10/05/13 01:25 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Are you sure they were cats? I have looked into this and there is a lot of conflicting info. But most agree that sometime in 08 was when the diesel cat was installed.
On diesel bombers forum many of the thought to be cats were either the muffler or resonator in the exhaust.
Converters on a diesel are news to me, my appologies for missinformation. And still not sure how they made that work. Since diesel fuel is such an oily product how do they keep from plugging and melting down the cat? What purpose does it serve? In a gas engine it burns up extra unburt emissions. This doesn't seem like it would work in a diesel engine.
[Re: hp383]
#1512220
10/05/13 01:48 PM
10/05/13 01:48 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Yep, they do have cats on diesels. Along with a bunch of other junk. My 2011 Ram has 5 separate devices in the exhaust. Even some of the earlier trucks had cats if they were on the left coast.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: Michael]
#1512225
10/06/13 09:15 AM
10/06/13 09:15 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
for my own education, are there sensors or something that can tell if it's installed or not? IT shouldn't be that hard to buy a section of pipe long enough to replace whatever component you're trying to remove.
a trick we do on the Dakota's when deleting the cat is to leave the downstream O2 sensor hooked up electronically, but zip tied to the frame rail so it's reading ambient air. tricks the computer into thinking that the cat is working REALLY well.
**Photobucket sucks**
[Re: 70Cuda383]
#1512226
10/06/13 12:17 PM
10/06/13 12:17 PM
rattler
Crofton, Ky.
Yep Tom, there are sensors. They are needed for what is happening at the engine. The delete kits get rid of EGR and the dumping of raw fuel to burn out the filters. If you do the deletes and don't change things downstream, you will set codes.
[Re: rattler]
#1512227
10/06/13 01:07 PM
10/06/13 01:07 PM
Posts: 196 West Central Indiana
Mr.Runum
You have to buy a tuner (if you can still get) I went with a Smarty Jr and you have to remove everything at the same time. DPF, EGR Cooler and install the tuner. I did away with the cat, dpr, egr cooler, and the piece on the intake. Turbo back exhaust w/muffler. Did the work myself, the whole 9ydrs was about $1,009.00. the truck will get 22mpg @65mph.
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
