Super Blue Brake Fluid not legal in the USA ? #1512190
10/04/13 03:39 PM
10/04/13 03:39 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
I have some of this on the shelf....I was going to be using it when I put the Viper / Brembos on my 72 Runner.
Anyway looks like this came out in August of 2013:Super Blue Brake fluid is now not available to use in the USA?
http://hooniverse.com/2013/08/16/braking-news-ate-super-blue-deemed-illegal-for-us-distribution/
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512191
10/04/13 03:59 PM
10/04/13 03:59 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
That sucks. Hopefully retailers keep carrying it for offroad use only.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Super Blue Brake Fluid not legal in the USA ? [Re: Uhcoog1] #1512192
10/04/13 04:04 PM
10/04/13 04:04 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
I just read your reply on the other thread about using the blue and the 200 and being able to tell the difference between the color for a complete fluid change indication.
I just called Tire Rack and they only have the ATI-200
The Super Blue is history.
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512193
10/04/13 04:49 PM
10/04/13 04:49 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
For those who might buy some for the shelf...
From ATE:
Life expectancy:
All Brake Fluids
With temps between -20 C and 40 C up to 5 years in the initially closed tins.
* once opened, use within 1 year
Datecodes on the product:
Brake Fluid Container: Day it was filled marked as day XXX plus year Y, e.g. 0787 = 78th day of 2007
Re: Super Blue Brake Fluid not legal in the USA ? [Re: Uhcoog1] #1512194
10/04/13 04:59 PM
10/04/13 04:59 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Part No.: 3327-Quantity
ATE Type 200 (Amber) DOT 4 Racing Brake Fluid
ATE Type 200 (Amber) DOT 4 Brake fluid is an ideal choice for handling the high demands placed on your brake system, regardless of whether you are involved in autocross, road racing or high performance street driving.
ATE Type 200 (Amber) Specifications:
DOT Rating: 4
Dry Boiling Point: 536° F
Wet Boiling Point: 396° F
Compatible With Other Fluids: Yes
Container: One liter metal can
ATE Type 200 is the same as ATE Super Blue Racing Brake Fluid, except with a DOT-compliant amber color. All other specifications are identical. ATE engineered the two fluids to have exactly the same performance. pegasus racing
Re: Super Blue Brake Fluid not legal in the USA ? [Re: ThermoQuad] #1512195
10/04/13 05:03 PM
10/04/13 05:03 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
DOT Rating: 4
Switching between the super blue and the ATE 200 was just too easy...
Re: Super Blue Brake Fluid not legal in the USA ? [Re: Uhcoog1] #1512196
10/04/13 05:06 PM
10/04/13 05:06 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ive benn running Motul RBF 600. Is it comparable/equal to the ATE?
Mopar to the bone!!!
Re: Super Blue Brake Fluid not legal in the USA ? [Re: 72Swinger] #1512197
10/04/13 07:13 PM
10/04/13 07:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512198
10/04/13 09:39 PM
10/04/13 09:39 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Super Blue is crap anyways. I boiled that stuff in my 2855 lbs. S2000 which is mostly stock.
I use Castrol SRF now, much better
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Super Blue Brake Fluid not legal in the USA ? [Re: RylisPro] #1512199
10/04/13 09:52 PM
10/04/13 09:52 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
How fresh was it when you boiled the Super Blue fluid?
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512200
10/04/13 10:21 PM
10/04/13 10:21 PM
Central PA
BartonHemi Offline
BartonHemi  Offline
Central PA
Castrol DOT 4 synthetic. Never boiled, never corroded, never a problem. 160 MPH door car, hard on brakes, never a problem. Same stuff we put in MB's and BMW's. Always no problem HTH HJ
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512201
10/04/13 10:50 PM
10/04/13 10:50 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I used a fresh brand new sealed bottle like I always do before each trackday, boiled at the next to last session at Thunderhill this past spring. Flushed it with Castrol SRF and did the same in the summer with higher ambient temps and pedal feel felt awesome all of the session start to end
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Super Blue Brake Fluid not legal in the USA ? [Re: PHJ426] #1512202
10/05/13 11:55 AM
10/05/13 11:55 AM
San Francisco Bay Area
MrAngry Offline
MrAngry  Offline
Motul RBF600 or RBF660. Match that up with a good set of pads, rotors and lines and you're good to go.
Never trust a pretty girl... or a lonely midget.
