Torqueflite vs Glide #1511989
10/03/13 08:41 PM
10/03/13 08:41 PM
North Eastern New York State
montessa Offline OP
montessa  Offline OP
I know this won't be very popular but I am considering changing over to a Powerglide. I would like to hear from guys whom had made the switch and what their results were. My car is 3700lbs and runs low nines. I have some Chrysler buddies that also bracket race that have made the switch with positive results. However, their cars are a lot lighter than mine. I think that the car will lose some time due to the taller first gear. I also know that the glide will be more consistent. How much time do you think is on the table? Comments?
Re: Torqueflite vs Glide [Re: montessa] #1511990
10/03/13 09:11 PM
10/03/13 09:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe my car is a similar combo to yours except its a cross ram w/ eddy 750s. Your car is both heavier and faster than mine (9.27@146.6, 3340). Why a glide? Mine doesn't spin at all. 10.5x31W ,4.10 If anything I think I could use more gear. My overall starting line ratio is 10.45. 1.80 glide w/4.56 would be 8.23. I think it would slow it up early. Mine ave 1.32-1.36 60 3.80-3.85 330. Pretty sluggish in the early portion of the run. However its a good bracket car and easy on the motor in the lights.
Doug
Re: Torqueflite vs Glide [Re: dvw] #1511991
10/03/13 09:46 PM
10/03/13 09:46 PM
montessa Offline OP
montessa  Offline OP
Dvw, traction is not my issue. Ever since I put ladder bars on the car traction is not the problem. However, reliability has been slipping. That is reason for checking out a glide.
Re: Torqueflite vs Glide [Re: montessa] #1511992
10/03/13 10:01 PM
10/03/13 10:01 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Post a timeslip to get many comments
The little old lady from Pasadena is back!
Re: Torqueflite vs Glide [Re: montessa] #1511993
10/03/13 10:03 PM
10/03/13 10:03 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Explain "Reliability has been slipping"...I've ran Glides for years in lighter cars, and consistency with a glide requires rebuilds on a regular basis.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Torqueflite vs Glide [Re: Barnstorm] #1511994
10/03/13 10:48 PM
10/03/13 10:48 PM
montessa Offline OP
montessa  Offline OP
My best was 9.08 at 147mph last year in the fall with mine shaft air and a big tail wind. I make somewhere around 80 to 100 passes a year. The motor dynoed at 910HP and 810Torque. I am just trying to see what kind of experiences other guys are having with similar setups. How many runs are you guys getting before tear downs? What is breaking and what kind of mods does your torqueflite have? Mine has an aluminum drum, steel plantaries, rear bearing support and hardened input shaft.
Re: Torqueflite vs Glide [Re: montessa] #1511995
10/04/13 12:18 AM
10/04/13 12:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though mine has some old super stock aluminum parts. Input and output shafts, planet carriers (3 pin), low roller(sprag) are all stock.
95 passes so far this year.
Doug
Re: Torqueflite vs Glide [Re: dvw] #1511996
10/04/13 01:58 AM
10/04/13 01:58 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
bone stock glide 1.76 internals 5 disc drum, t/b valve body. 4 years with 6,000 plus launches ZERO parts no failures, unit cost about 500. total.
1.25 60' 8.58 et
home of the
Sox and Martin Hemi Duster
Re: Torqueflite vs Glide [Re: montessa] #1511997
10/04/13 07:45 AM
10/04/13 07:45 AM
gregsdart Online content
gregsdart  Online Content
I have always run a Torqueflite, but it wasn't easy making it consistent. If your goal is winning bracket races, and that is more important, go glide if you want to. It really is helpful in consistency due to one shift, and that one being down track far enough that it is easier to hit the exact rpm. The 727 takes more power to turn, so there is some trade off there, and that combined with too much starting line ratio for fast cars is probably why some say the glide is faster, some say it is slower. It really depends on the power curve, weight, tires, etc. If a car has 1000 hp and weighs 2500 lbs, it would be a real bear to get it off the line cleanly with a Torqueflite with a 2.45 low gear.
I don't worry about what others think about what i do; none of them write the checks, I do. And I bet, so do you.
Re: Torqueflite vs Glide [Re: HEMIFRED] #1511998
10/04/13 11:45 AM
10/04/13 11:45 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
1.25 60' 8.58 et
Are you sure about the 6000 passes? 6000 passes over 4 yrs is 1500 per year average. That's a lot of passes per year.
Re: Torqueflite vs Glide [Re: SCDaytona] #1511999
10/04/13 12:08 PM
10/04/13 12:08 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
1.25 60' 8.58 et
He may be talking about the rpm he launches at instead of how many runs
Re: Torqueflite vs Glide [Re: SB412DUSTER] #1512000
10/04/13 12:32 PM
10/04/13 12:32 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
1.25 60' 8.58 et
correct thank you
home of the
Re: Torqueflite vs Glide [Re: HEMIFRED] #1512001
10/04/13 09:49 PM
10/04/13 09:49 PM
montessa Offline OP
montessa  Offline OP
Fred, what kind of difference in performance did you have when you changed from 3 speed to glide? I am assuming that you did run a torqueflite at one time. Also how much does your car weigh? Thanks Jim.
Re: Torqueflite vs Glide [Re: montessa] #1512002
10/04/13 10:39 PM
10/04/13 10:39 PM
Central PA
BartonHemi Offline
BartonHemi  Offline
Central PA
ATI glide since 98, almost 3000 (yes) passes. 1 planatary explosion, killed the dana 60 and driveshaft on the line. Sounded like the devil right next to me. Current converter is @ 350 passes, it's done after next week. Best 60 ft 1.24, best et 8.47 @ 159. Racepac shows converter a 1.08 in the lights. 16 race wins since 07. NEVER won a race with a Torqueflite. I'm sure it's slower but it's my racing friend. I run the old one way safety clutch so when you come off the gas it returns to idle. Not very popular but it's saved me motor damage mulitple times. Wouldn't leave home without it. HTH HJ Only 3 failures to my log book. Killer service from me all year and rebuilds from Scott's Transmissions in PA. An ATI dealer
Re: Torqueflite vs Glide [Re: montessa] #1512003
10/05/13 12:19 PM
10/05/13 12:19 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
never ran a 3 speed. my car weighs about 2500.
home of the
Re: Torqueflite vs Glide [Re: HEMIFRED] #1512004
10/05/13 03:28 PM
10/05/13 03:28 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Wow that's light!!!!
Anyway, if you want a transmission with less rotational inertia but still being a "mopar" you can always go the Pro-Flight. Costs a lot, though.
This post is available in double vision where drunk.
Re: Torqueflite vs Glide [Re: bwdst6] #1512005
10/05/13 08:03 PM
10/05/13 08:03 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I also run a glide in my turbo hemi road runner.
it's an ATI unit with a lock-up conveter.
cost 10,999.99
home of the
Re: Torqueflite vs Glide [Re: HEMIFRED] #1512006
10/05/13 08:55 PM
10/05/13 08:55 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Just think of how cheap it would be if the entire car was GM parts!
Re: Torqueflite vs Glide [Re: bwdst6] #1512007
10/05/13 10:48 PM
10/05/13 10:48 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
It doesnt have to be all mopar. I run a glide in mine to. Run a 727 in the cuda though
Re: Torqueflite vs Glide [Re: bwdst6] #1512008
10/05/13 10:48 PM
10/05/13 10:48 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
like a top fuel motor not a single GM part in my transmission. Being the MOPAR purist that you are which Mopar transmission that is capable of handling close to 3,000 HP would you recommend? 727 or 904
home of the
