I have swapped a stock M.W. cross ram intake and stock unported M.W. cylinder heads with dual 750 Carter OEM carbs to a set of 906 heads with a Eddy TM7 intake and a Holley 750 D.P. carb, that car slowed down .18 ET and 2 MPH in the 1/4 mile by going smaller on the heads and carb size
I don't know of anyone who has done the exact same swap your asking about but I have tried a bunch of different size carbs on a motor similar to yours including going from a TM7 with a 600 DP to 700 DP, to a bunch of different bigger carbs and then to a six pak set up and ending up with Mopar M1 single plane dominator flange with a Holley 1050 CFM Dominator carb on the same car within three months of each other. The car ran quicker ET and more MPH with each larger size carb. change
Do it and let us know how your car reacts to the change
Crossrams are cool and look good also
