Tunnel Ram Carbs can I run 1850s?
#151197
11/15/08 01:10 AM
11/15/08 01:10 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I've got a 440 in the works. 9:1 compression, 500 lift cam, .254 duration at .050 solid cam, home ported 906 heads. I plan on running a tunnel ram, and already have a pair of 1850-3 carbs. I think 450 cfm holleys would be a better choice, but has anyone run a pair of 1850s?
Or, what carter carbs would be a good choice?
Re: Tunnel Ram Carbs can I run 1850s?
[Re: NTOLERANCE]
#151198
11/15/08 01:42 AM
11/15/08 01:42 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I need to find an original dual TQ top intake.
I have several matching sets.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: NTOLERANCE]
#151199
11/15/08 08:47 AM
11/15/08 08:47 AM
Posts: 2,346 west palm beach, florida
modelmakerinc
NTOLERANCE
I think you will be fine, I use a pair, straight OTB Holley 1850's on my 509 cam 10:8 comp 440 with home ported 346 iron heads. It runs sweet on the street and has only opened up the secondaries a couple of times. It really depends on how you drive.
I put 1 step lighter secondary springs and I could go more. I am going to put on a balance tube to the vacuume so they get a balanced draw.
here is a pic of the set up. Also it is important to use four hole spacers under the carbs to give the carbs a stronger signal
