8.25 ?
#1511927
10/03/13 04:18 PM
10/03/13 04:18 PM
Posts: 172 IL,USA
bdusted440
IL,USA
Well now that I'm back in the states and am saving back up for a purchase I'm committed to . I'm trying to get info on the 8.25 rear. I have a 93 Dakota sport with the 8.25 with a 3.55 sure grip. The diff is the same width as my 74 duster that has a 7.25. I want to swap them out but the Dakota has a 6 bolt pattern. do all the 8.25 use the same axle? can I swap out an older set to get 5 lug? or could I get them redrilled? thanks
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
Re: 8.25 ?
[Re: bdusted440]
#1511928
10/03/13 05:12 PM
10/03/13 05:12 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Be carefull, you might not have a real 8.25 rear in that Dakota Sport. The newer rears resemble the 8.25,s but are actually 7.25,s
Either that or the newer 8.25,s are built like the older 7.25,s
I had what I thought was a newer 8.25 in a 90 Dakota Sport, but when I removed the back cover it was as chincy as the old 7.25 were.
I dont recall if I confirmed the cover bolt count, as the 7.25,s have 9 and the 8.25,s had 10.
I had just assumed it was the 8.25 by its looks and bigger mass compared to the old 7.25 rears. I was just checking this rear for its gear ratio as it was a parts donor truck, and I was considering keeping the rear. After inspection, off to the scrap it went.
Re: 8.25 ?
[Re: Sport440]
#1511929
10/03/13 05:47 PM
10/03/13 05:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
later 7.25 rears have a 10 bolt cover too.
Just observe the shape of the cover, see tech archives.
Re: 8.25 ?
[Re: Sport440]
#1511931
10/03/13 06:40 PM
10/03/13 06:40 PM
Posts: 172 IL,USA
bdusted440
IL,USA
we ordered it new with the 8.25 and suregrip.
