4 LINK ADJUST #1511914
10/03/13 03:48 PM
10/03/13 03:48 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi,
car pulls to right on launch, last time we turned right lower bar , dont remember if we made it longer or shorter, any tips?
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 4 LINK ADJUST [Re: 440lebaron] #1511915
10/03/13 03:52 PM
10/03/13 03:52 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Preload is done on the right(passenger) upper link.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: 4 LINK ADJUST [Re: 440lebaron] #1511916
10/03/13 04:36 PM
10/03/13 04:36 PM
Sterling Heights, MI
John_T_Brown Offline
hi,
Turning right = more preload (shortened), turning left = less preload (lengthened). This is adjusted on the upper right bar one flat at a time. If you have to adjust more than three flats something else is maladjusted.
If it ain't broke fix it anyway!
Re: 4 LINK ADJUST [Re: John_T_Brown] #1511917
10/03/13 04:39 PM
10/03/13 04:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Like they said....
Re: 4 LINK ADJUST [Re: Al_Alguire] #1511918
10/03/13 04:52 PM
10/03/13 04:52 PM
westerly, ri. usa
westerly, ri. usa
thanks,
s/g maple grove next week dutch classic and hemi shoot out
Re: 4 LINK ADJUST [Re: 440lebaron] #1511919
10/03/13 05:15 PM
10/03/13 05:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good luck. I will be racing the Jegs Sportsnationals here next weekend myself. Hopefully I drive better than I did in Salt Lake
Re: 4 LINK ADJUST [Re: 440lebaron] #1511920
10/03/13 05:17 PM
10/03/13 05:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hi,
gary
if you adjusted the bottom bar you just screwed up the rear being square.
Re: 4 LINK ADJUST [Re: Quicktree] #1511921
10/03/13 05:34 PM
10/03/13 05:34 PM
westerly, ri. usa
westerly, ri. usa
that was many years ago when chassis was new/fresh and car was pulling to right down track
gary
Re: 4 LINK ADJUST [Re: 440lebaron] #1511922
10/04/13 08:09 AM
10/04/13 08:09 AM
Guitar Jones Offline
Bottom bars set the wheelbase, upper bars set the pinion angle and right upper bar then sets the preload. That's how I do mine.
Re: 4 LINK ADJUST [Re: Guitar Jones] #1511923
10/04/13 11:09 AM
10/04/13 11:09 AM
westerly, ri. usa
westerly, ri. usa
only gona have 2 time shoots...soooo make it longer or shorter??
Re: 4 LINK ADJUST [Re: 440lebaron] #1511924
10/04/13 03:55 PM
10/04/13 03:55 PM
Right upper bar shorter, if you have a diagonal link be sure to recenter the axle after adjustment with all the weight on it (ride height).
Re: 4 LINK ADJUST [Re: Guitar Jones] #1511925
10/04/13 04:22 PM
10/04/13 04:22 PM
westerly, ri. usa
westerly, ri. usa
GOTCHA
Re: 4 LINK ADJUST [Re: Guitar Jones] #1511926
10/04/13 04:23 PM
10/04/13 04:23 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
and disconect any antiroll links
home of the
Sox and Martin Hemi Duster
