Screamer means high RPM... hydraulic flat tappet means maybe lifter pump up issues at high RPM. I believe it is both and art and science to get a hydraulic to work >6000 RPM. It depends on heads and cam and RPM target.
That said, screamer small block screams for a mechanical cam. I may be biased but see no advantage to a hydraulic in a high po application. Both hydraulic and mechanical need adjustable lifters and I think setting valve lash on a solid is easier than dialing in pre-load on a hydraulic.
