440 breaking up at 5500rpm
#1511640
10/02/13 09:05 PM
10/02/13 09:05 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
I recently swapped cams in my 440 from the MP 509 hyd to the Lunati 60303 (.494/.513, 268/276, 226/234 @.050"). I finally got to the point last weekend where I opened the car up for a WOT pull while tuning the carb and noticed that when I get up to 5500-5700rpm the car starts breaking up like it has hit the rev limiter.
I tried a different carb this past weekend and there was no difference. I tried a different chip in my MSD box thinking the one in there may have went bad but still no difference. The AFR meter is reading around 13.0 at the leanest point so it isn't running out of gas. As soon as I shift from 1st to 2nd or 2nd to 3rd the car stops breaking up and starts pulling hard again which to me means it has enough fuel as well. I also never had any fuel supply issues with the 509 cam.
Could this be as simple as a bad plug, plug wire, or distributor cap? Other than that I am thinking valve springs but I have the ootb eddy springs on their heads that are rated for up to .600 lift. I never had an issue with them when using the 509 cam?
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: 440 breaking up at 5500rpm
[Re: Hot 340]
#1511642
10/02/13 09:40 PM
10/02/13 09:40 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I am using comp pro mag adjustable rockers. I had 3/4 turn preload on them and tried taking a quarter turn out but it didn't make a difference.
I have an MSD distributor. When you mention wobble do you mean the cap being loose or he rotor actually wobbling? The cap bolts down and is very secure.
[Re: tywebb2]
#1511643
10/02/13 10:01 PM
10/02/13 10:01 PM
Posts: 3,397 Pa
Hot 340
Pa
its probably neither of those then...I had a wore out factory distributor that did that. Might be your msd box going bad?
[Re: Hot 340]
#1511644
10/02/13 10:37 PM
10/02/13 10:37 PM
tywebb2
super gas
super gas
Jarrettsville, MD
Kind of odd how the problem showed up right after the cam swap?
[Re: goldmember]
#1511646
10/03/13 12:16 AM
10/03/13 12:16 AM
tywebb2
super gas
super gas
Jarrettsville, MD
That is kind of what i was afraid of. What do you think the open and seat pressures are for the eddy valve springs are? They list on their website that they are rated for up to 600 lift but nothing about the open and seat pressures?
[Re: tywebb2]
#1511648
10/03/13 01:35 AM
10/03/13 01:35 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
That is kind of what i was afraid of. What do you think the open and seat pressures are for the eddy valve springs are? They list on their website that they are rated for up to 600 lift but nothing about the open and seat pressures? [/quote) I'd pull at least 1 and check it. Are the springs new?
[Re: 383man]
#1511651
10/03/13 11:42 AM
10/03/13 11:42 AM
dogdays
Your problem is classic, valve springs incorrect for the cam. The Voodoo cam line, as well as the Comp XEHL line, and all of the Hughes cams, use very high lifter acceleration rates that require matched springs for success. The cam manufacturer is the one to ask about springs.
R.
[Re: Harley]
#1511653
10/03/13 10:04 PM
10/03/13 10:04 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I talked to Lunati tech this evening and they seemed to think it could be too much preload...lifters pumping up at high rpm and not allowing the valves to close. They suggested taking a quarter turn out and trying them at only 1/4 turn preload. If that doesnt work then look at the springs. Said I should have 120 seat and 320 open. Safe range would be 100-120 seat and 300-325 open.
I did pull my distributor cap and cleaned that up and bought a new set of plugs to throw in it too (autolite 3924).
[Re: Sport440]
#1511655
10/03/13 10:53 PM
10/03/13 10:53 PM
tywebb2
super gas
super gas
Jarrettsville, MD
My heads/springs are probably about 8 years old with very low mileage on them.
I just found eddy specs on the springs.
115# seat 280# open at .500" Of course I need to check one to verify but looking at the factory spec would that mean I don't have enough pressure on the open?
[Re: Sport440]
#1511657
10/04/13 12:11 AM
10/04/13 12:11 AM
tywebb2
super gas
super gas
Jarrettsville, MD
I wonder if I should pull the intake and all lifters so I can bleed them down and start from scratch setting lifter preload. I went back in and reset it after the initial break in (which I now know was a mistake). Setting the preload with the intake on makes it a little more tricky and I know some of the lifters were pumped up which is bad too...right?
