Re: 1 7/8 headers for 68b-body
[Re: KOS]
#1511619
10/03/13 12:10 PM
10/03/13 12:10 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
thx yours a low deck?its the angle plugs that are a concern i dont think the hookers will work.
440. call Eddy and see what they recommend.
[Re: Mr.Yuck]
#1511620
10/03/13 12:30 PM
10/03/13 12:30 PM
Posts: 5,160 Texas
dannysbee
Texas
The tti 383-178 looks like its recommended for a b-body low block with eddies.
Getting old just means you were smarter than some and luckier than others.
[Re: Mr.Yuck]
#1511622
10/03/13 05:37 PM
10/03/13 05:37 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
I'm using 2" supercomps... easy fit and easy to get to the plugs. I had a set of cheapo 1 3/4" on it before and these things drop in compaired. I was going to use the hooker 1 7/8 but after trying one side I hung them back on the wall. The 2" are 2 piece so they install pretty easy. No issues w/ plug wires either. I only use one plug jacket. I have stage VI heads not sure how'd they'd work w/ e-heads..
Pretty sure stage VI's ahve staright plugs , his issue is the angle plugs on the eddies , only TTi has addresses angle plugs , just about everything else is centered around people still running 906's
