Re: tuning help for more or less stock rear suspension.
[Re: Cab_Burge]
#1511346
10/02/13 02:27 PM
10/02/13 02:27 PM
Posts: 164 Savannah, GA
mopar400
Savannah, GA
My buddy at work has a 72 Maverick we take to the track some. He put it all together as a street car with a 302, C4, 3.80 gear and Cheap "stall" off Ebay. It looked good on launch but his 60's were pretty bad, the car wouldn't spin his small street tires and it seemed dead out of the hole. We talked it over and he went with a Edge custom converter. As soon as it was installed it was clear the huge difference. It would blow the tires off on the street. Went back to the track and it picked up 6-8 tenths (8.8's to 8.0's) in the 1/8th with no other changes. He says the car even drives better now on the street.
1965 Fury II
1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4
(1999 Magnolia Drag strip track champion)
1992 Jeep XJ Crawler
[Re: aspenrt360]
#1511347
10/02/13 02:32 PM
10/02/13 02:32 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
What size tires are you running? While its true that a shorter tire decreases the contact patch, it could give you a shorter effective gear ratio. I run 3.23's and have 275/60's for the street, which are ~28" tall, then switch to some 26x10 ET streets for the track. If you are only going to race it a few times a year, I would keep the gear and get a set of shorter stickies to run at the track.
You shouldn't need to worry about tuning until you are breaking traction, but generally you want to free up the front and ensure you are getting adequate travel to improve weight transfer. It's going to take alot to get that car out of the hole.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1511348
10/02/13 06:36 PM
10/02/13 06:36 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I don't have much to add, but I am basically in the same boat with my '85 D150 except I have even worse 60' times. I need to figure how to get the power to the ground while still maintaining good comfortable street ability. In my case though, I spin right through first and most of second gear (833 O/D trans).
Outcast Dodge guy.
