Re: CSR Shield with a JW Ultra Bell
[Re: hemi-itis]
#1511143
10/02/13 09:01 AM
10/02/13 09:01 AM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
On my Dart I used an Ultrabell and a short Lofgren blanket.
[Re: ProSport]
#1511144
10/02/13 12:09 PM
10/02/13 12:09 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Ultra bell and stroud blanket here
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: hemi-itis]
#1511145
10/02/13 12:14 PM
10/02/13 12:14 PM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
If you use the ultra bell,you'll only need to cover the trans.You can use a blanket.
Two things....Its a street car mostly, and trapped heat is bad.
Second, when it absorbs all the trans oil, it leaks it everywhere...Already been down that road once.
Got a blanket that only covers the very top of the trans up to the edge of the bell, I might consider it, maybe. I do not need one that covers the whole trans, the linkage, the cable and the whole back of the engine, and then for extra safety, wraps around the bottom of the trans too...Its like a bed spread instead of just covering the min required.
[Re: 1967dartgt]
#1511146
10/02/13 12:22 PM
10/02/13 12:22 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
So the ultra Bell eliminates the need for a FLEX PLATE SHIELD? But you still need a TRANS SHIELD for 9.99 and quicker? I agree with Dragula not a fan of blankets When it's cold enough to need a blanket, the Barracuda is in the garage. Don
