Race trailer floor paint #1510884
10/01/13 05:51 PM
10/01/13 05:51 PM
Ames, Iowa
LoneMopar Offline OP
Ames, Iowa
What holds up well on an enclosed race trailer floor?
I have used epoxy floor paints but they are supposedly not for wood, only for concrete.
What have you used that lasted a few years?
Re: Race trailer floor paint [Re: LoneMopar] #1510885
10/01/13 05:59 PM
10/01/13 05:59 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
I used battleship gray porch paint. Hasn't peeled off in 2 yrs. It's time for a new coat though.
Re: Race trailer floor paint [Re: rickraw] #1510886
10/01/13 06:12 PM
10/01/13 06:12 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Re: Race trailer floor paint [Re: SIKPUP] #1510887
10/01/13 07:54 PM
10/01/13 07:54 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Option b
Menards has heavy duty vinyl trailer flooring by the roll
My buddy did his, cost $180.00 , everything needed glue, trim,etc
His is 26 feet long
Turned out looking awesome
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Race trailer floor paint [Re: rickraw] #1510888
10/01/13 09:36 PM
10/01/13 09:36 PM
Minn
SportF Offline
SportF  Offline
Minn
I've used the Floor and Porch paint too. With a couple of coats down its a nice finish, that can be cleaned easily. Good luck!
Re: Race trailer floor paint [Re: SportF] #1510889
10/02/13 01:04 PM
10/02/13 01:04 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Start with a wood primer for marine use, then use the porch paint. The marine primer seals the wood against moisture.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Race trailer floor paint [Re: SportF] #1510890
10/02/13 01:04 PM
10/02/13 01:04 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
porch and patio with diamond plate under tires
wood has to be clean
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Race trailer floor paint [Re: 440lebaron] #1510891
10/02/13 02:19 PM
10/02/13 02:19 PM
Any one have any ideas on how to clean the used wood with oil and rubber on it before painting it
Re: Race trailer floor paint [Re: Slingshot383] #1510892
10/02/13 04:55 PM
10/02/13 04:55 PM
tboomer Offline
tboomer  Offline
I think this would work well. Just like the stuff used on treated decks. I think it has been quite a while since Steve had his wood cleaned.
Re: Race trailer floor paint [Re: Cab_Burge] #1510893
10/02/13 05:24 PM
10/02/13 05:24 PM
Ambridge, Pa.
Ambridge, Pa.
Throw down some oil dry & grind it in with ur feet, then wash with lacqure thinner. Sand, prim & paint.
Re: Race trailer floor paint [Re: 440lebaron] #1510894
10/02/13 07:04 PM
10/02/13 07:04 PM
Locomotion Offline
Locomotion  Offline
Where the tires sit will eventually wear through the paint. The diamond plate will also help keep the tires from sliding around. Doing the whole track where the tires will roll is even better, but it gets expensive. Local sheetmetal shop can sheer lengths & widths as needed.
