Re: Should have made power steering aluminum [Re: RylisPro] #1510750
10/06/13 08:42 AM
10/06/13 08:42 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
The Borgeson is 16 lbs lighter.
I checked out the Borgeson unit and damn its expensive!
http://www.borgeson.com/xcart/home.php?cat=143
$749 for the power steering unit and $130 for the steering coupler, also they list the unit at 25 lbs.
37 lbs. - 25 lbs. = 12 lbs.
Borgeson $749 - Firm Feel power steering $359 = $390
$390 / 12 lbs. = $32.50 per pound!
If I had known about the Borgeson first and how heavy the OEM power steering unit is, I might have gotten it but I am kind of glad to save all that money.
I think it would be better to invest that $390+ I saved in an aluminum small block
I sell the box for 675. You still need a coupler and fittings to make it work, but its a different world compared to the OE boxes.
Re: Should have made power steering aluminum [Re: relax383] #1510751
10/06/13 03:44 PM
10/06/13 03:44 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I am not sure aluminum would be a good choice. Thermal expansion and the pressures in the box over time might lead to failures more often then with Iron. Also porosity of an aluminum casting might be a problem with the high PSI of power steering. These might be reasons but I am no expert.
Those are valid concerns, but by not making just an exact copy, and improving some design aspects with an alum version, they should be solvable IMO.
And I am not sure how the alum rack and pinions deal with these issues, since the designs differ.
Re: Should have made power steering aluminum [Re: jcc] #1510752
10/06/13 09:17 PM
10/06/13 09:17 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Dick Ross suggested.... steel sleeve for the piston bore.
Re: Should have made power steering aluminum [Re: BergmanAutoCraft] #1510753
10/10/13 10:07 PM
10/10/13 10:07 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Could not be more happy with mine, made a world of differance, money well spent!
Re: Should have made power steering aluminum [Re: 74_360_Cuda] #1510754
10/11/13 02:07 PM
10/11/13 02:07 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
How about Flaming River?
Re: Should have made power steering aluminum [Re: 1972CudaV21] #1510755
10/11/13 02:24 PM
10/11/13 02:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
594 views, and no has been able weigh an empty mopar PS housing, to gauge what weight savings might be in alum?
Re: Should have made power steering aluminum [Re: jcc] #1510756
10/11/13 06:39 PM
10/11/13 06:39 PM
Long Island, NY USA
Long Island, NY USA
Now that we have the new Borgeson box, which is lighter, smaller and has light years better feel, why would anyone bother remaking the old case in alum? I don't get it. If you think it would cheaper, I seriously doubt it when you figure in design, tooling and production costs. What am I missing? I know the Borg box is expensive, but I'm thankful they even made it...
Re: Should have made power steering aluminum [Re: BergmanAutoCraft] #1510757
10/11/13 06:43 PM
10/11/13 06:43 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Definitely....the aftermarket support for Mopar parts is thin at best.
Someone steps up to the plate and the next guy is trying to make it cheaper......
And then we get into the weeds of making parts in China to keep costs down and next the poop hits the
Re: Should have made power steering aluminum [Re: PHJ426] #1510758
10/11/13 06:54 PM
10/11/13 06:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Someone always thinks they have a better idea. I dont care if the factory box was re-made in fricken titanium, it would still be way to BIG for my combo. DUH!
Mopar to the bone!!!
Re: Should have made power steering aluminum [Re: 72Swinger] #1510759
10/12/13 06:00 PM
10/12/13 06:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I for a number of years bugged MP at the shows many years ago to build an alum 8.75, They said they never would. Also tried to convince them they needed an alum SB. Same answer. For years I was one of many that often pleaded for a Moparts handling forum. Same answer. Strange how that all turned out.
I am not pleading for an alum PS box until I have SOME idea what it might save in weight first. Because questions don't cost much.
Re: Should have made power steering aluminum [Re: jcc] #1510760
10/12/13 06:17 PM
10/12/13 06:17 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I think they should make the center steering link in aluminum as well
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: jcc] #1510761
10/12/13 06:43 PM
10/12/13 06:43 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Keeping in mind the forces a power steering box can excert on a K-member, for it to be cast in aluminium, it would have to be beefed up in certain areas to prevent failure due to stressed mounting points.
Even when started out with a Borgeson sized box, I think because of the metal added for beefing up it would add enough weight that in the end one might only gain a couple of pounds over a castiron one.
Don't forget the pricetag either.
The 'new' Borgeson box is not cheap as it is. An aluminium version could easily retail for close to $800 to a grand.
At that point a rack-conversion has been starting to look very interesting already.
Why not go for some aluminium spindles while we're at it?
Re: Should have made power steering aluminum [Re: BigBlockMopar] #1510762
10/12/13 09:25 PM
10/12/13 09:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well the Rms and company power racks are significantly less robust in every way, and have been on millions of cars, although the forces are different, but the tire forces fed back to steering gear is the same, only multiplied by the length of the pitman arm.
That is a given, but looking at the alum 8.75 it is only slightly thicker, although some webbing has been added, and its reported 10% stiffer than the OEM CI unit.
Maybe, but until we WEIGH one, we are just moving electrons with banter.
Everything comes down to price eventually, but if the borgeson box had a little extra competition, it might also reduce its price.
Thats a different topic.
