Should have made power steering aluminum #1510730
10/01/13 02:41 PM
10/01/13 02:41 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I got a Firm Feel stage 2 power steering yesterday and damn its heavy 37lbs! Does power steering need to have cast iron to hold in the fluid pressure? If not, then someone should make an aluminum unit
On another note, how many of you run the fast ratio Pitman arm? Is it worth it?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510731
10/01/13 03:09 PM
10/01/13 03:09 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
With the longer Fast Ratio Pitman arm, make certain you also install the longer Idler arm so to have equalized left/right turning radius. It was a factory oversight to not install the longer Idler arm when the Fast Ratio ps gearbox was optioned (which automatically gave you the longer Fast Ratio Pitman arm).
Re: Should have made power steering aluminum [Re: Mopar Mitch] #1510732
10/01/13 03:21 PM
10/01/13 03:21 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I've got the FF stage 3 box and the fast ratio arms. I'm happy with it! Just waiting to see what Bergman Auto Craft comes up with in regards to a smaller diameter tuff wheel!
Fast ratio arms are nice, besides the weight I saved by taking this off made it all worth while!
http://www.amazon.com/AutoLogix-8356-Heavy-Steering-Spinner/dp/B000IG1SDY/ref=cm_cr_pr_product_top
Re: Should have made power steering aluminum [Re: Mopar Mitch] #1510733
10/01/13 03:53 PM
10/01/13 03:53 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Thanks Mitch!
I'm going to get the longer idler arm as well as the rest of the goodies Firm Feel has to offer. Problem is that although their stuff is not too expensive, when you get a lot of parts it adds up $$$!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510734
10/01/13 04:52 PM
10/01/13 04:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The Borgeson is 16 lbs lighter.
Mopar to the bone!!!
Re: Should have made power steering aluminum [Re: RylisPro] #1510735
10/01/13 05:10 PM
10/01/13 05:10 PM
AndyF Offline
AndyF  Offline
I don't think there is any reason a PS box couldn't be made from aluminum. The factory just did it the cheapest way possible back in the 60' and 70's. FFI doesn't have enough cash to re-tool the entire case so they use factory cores. It would cost $$$ to tool up an aluminum PS box.
I bet a person could build a billet PS box. Probably cost a few grand though. It cost me $3000 to build the first SB billet timing chain cover.
Re: Should have made power steering aluminum [Re: AndyF] #1510736
10/01/13 05:28 PM
10/01/13 05:28 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
So can anybody weigh the CS housing by itself and we can make an educated guess as to a projected weight savings by having an alum casting, with the first guess assuming no increases in thickness as a starting point?
Re: Should have made power steering aluminum [Re: jcc] #1510737
10/01/13 05:38 PM
10/01/13 05:38 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I've had a FF stage 2 box with the fast ratio idler and pitman arms on my challenger for about 15 years and am very happy with it.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Should have made power steering aluminum [Re: AndyF] #1510738
10/01/13 05:47 PM
10/01/13 05:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Then why is the manual box aluminum?
the older stuff (30's and 40's) were iron, muscle car era is aluminum. Is there anyone that makes an aluminum recirc ball power steering box?
Don't be the exception.
Re: Should have made power steering aluminum [Re: 72Swinger] #1510739
10/01/13 06:37 PM
10/01/13 06:37 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I checked out the Borgeson unit and damn its expensive!
http://www.borgeson.com/xcart/home.php?cat=143
$749 for the power steering unit and $130 for the steering coupler, also they list the unit at 25 lbs.
37 lbs. - 25 lbs. = 12 lbs.
Borgeson $749 - Firm Feel power steering $359 = $390
$390 / 12 lbs. = $32.50 per pound!
If I had known about the Borgeson first and how heavy the OEM power steering unit is, I might have gotten it but I am kind of glad to save all that money.
I think it would be better to invest that $390+ I saved in an aluminum small block
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510740
10/01/13 07:05 PM
10/01/13 07:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a pic of mine on the scale reading 21#. You also need to Subtract the cost of the fast ratio arms from you equation since they aren't needed.
Re: Should have made power steering aluminum [Re: 72Swinger] #1510741
10/01/13 07:21 PM
10/01/13 07:21 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
ok
Firm Feel 37 lbs. - Borgeson 21 lbs. = 16 lbs
Borgeson power steering $749 - Firm Feel power steering $359 = $390
$390 / 16 lbs. = $24.375 per pound
Also, the Borgeson is 14:1 ratio while Firm Feel's fast ratio arm is 12:1
Would that make a big difference?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510742
10/01/13 08:44 PM
10/01/13 08:44 PM
IN
ahy Offline
ahy  Offline
IN
Related topic... you probably already know that the long arm can interfere with headers. Some fit, many do not. I believe FF has a list of known combos that work and others that don't.
Re: Should have made power steering aluminum [Re: AndyF] #1510743
10/01/13 08:59 PM
10/01/13 08:59 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Hummm interesting! I'm needing a project this winter! I've got a few bigger blocks of 7075 aluminum kicking around....
Re: Should have made power steering aluminum [Re: Supercuda] #1510744
10/01/13 09:01 PM
10/01/13 09:01 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Good question?
Re: Should have made power steering aluminum [Re: ahy] #1510745
10/01/13 09:12 PM
10/01/13 09:12 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I saw that list on their site
http://www.firmfeel.com/fastrati_e.htm
It says the 1-3/4 TTI's fit on a small block
I have a set of 1-5/8 Doug's D453 headers on my 340
Since the TTI's are a copy of the Doug's I should be good there
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510746
10/01/13 11:45 PM
10/01/13 11:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
ok
how much did the fast ratio arms set you back?
Re: Should have made power steering aluminum [Re: 72Swinger] #1510747
10/02/13 12:42 AM
10/02/13 12:42 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I haven't gotten the arms yet but they are $195 for the fast ratio Pitman & $90 for the fast ratio idler
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Should have made power steering aluminum [Re: RylisPro] #1510748
10/02/13 02:59 AM
10/02/13 02:59 AM
Mopar Mitch Offline
Mopar Mitch  Offline
Ryliss... I have small block, Hooker 1-3/4" comp-series and they fit OK. I think the BB engines with headers are more a selected fit issue with the long arms vs the small block application.
Re: Should have made power steering aluminum [Re: RylisPro] #1510749
10/06/13 07:13 AM
10/06/13 07:13 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
I am not sure aluminum would be a good choice. Thermal expansion and the pressures in the box over time might lead to failures more often then with Iron. Also porosity of an aluminum casting might be a problem with the high PSI of power steering. These might be reasons but I am no expert.
