Re: Over Center clutch pedal spring length 68 GTX
[Re: sawdust]
#1510470
09/30/13 10:38 PM
09/30/13 10:38 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Give Brewers a call http://www.brewersperformance.com/products.asp?cat=43While you got your OC spring off make sure to inspect the pin (especially the rear)that the spring rides on. My Challenger's clutch pedal made all kinds of creeks and groans during it's travel...this is what my OC spring pin looked like.
[Re: sawdust]
#1510471
10/01/13 02:35 PM
10/01/13 02:35 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The one I removed from my '68 RR is 7 13/16" outside.
[Re: KillerBee]
#1510472
10/01/13 10:08 PM
10/01/13 10:08 PM
Posts: 1,022 Green Lane, PA
sawdust
Green Lane, PA
Mine was worn on the other side like yours, but someone turned it around and welded it in with some bird poop looking welds. Talked with Jamie Passon as he is nearby and a great guy to deal with. New pin on the way. Looks like I will be scrapping the old brackets and putting everything else in a spare setup I have. Spring seems to be the correct one after I checkd my 66 Hemi, and Jamie also confirmed. Thanks Jamie
