Indy Heads-Boosted Stroker Question #1510437
09/30/13 09:58 PM
09/30/13 09:58 PM
Omaha, NE
dart69bigblock Offline OP
Omaha, NE
I am going to be building a boosted low deck stroker and plan on 900-1000 at the crank. I am leaning towards Indy heads but am not sure which ones. I have found several used sets of Indy SR heads that have CNC'd and opened up to MW. Also on Moparts there's a set of Big EZ heads for sale. I know those don't flow as well on the exhaust side as the SR or 440-1 heads though. I know the 440-1 head is probably the best choice for maximum power but what are people's thoughts on a set of SR's with a good port job or the Big EZ's? I am not concerned with the exhaust port location or having to use offset rockers so those aren't really negatives in my decision. I am more concerned with how they will perform at that power level. Thank you for any advice you can provide.
Chris
Re: Indy Heads-Boosted Stroker Question [Re: dart69bigblock] #1510438
09/30/13 10:19 PM
09/30/13 10:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If Dizusters almost stock 360 can make 750-775 HP (10.08@136/3700lbs). At the desired level I can't believe it really matters what head you use. That goal should easily be met with any aftermarket BB head.
Doug
Re: Indy Heads-Boosted Stroker Question [Re: dvw] #1510439
10/01/13 01:03 PM
10/01/13 01:03 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
If you're boosted, then port velocity will be a given, look at the 572-13 heads, they really flow some air and will make it easier to make power.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Indy Heads-Boosted Stroker Question [Re: dart69bigblock] #1510440
10/01/13 01:08 PM
10/01/13 01:08 PM
SoCal
Brian Hafliger Offline
SoCal
Chris
How is your hood clearance? SR's will be taller than the rest. I love the SR's, they work really well.
I don't think you can go wrong with either the SR's or a good -1 cnc ported head.
Brian
Brian Hafliger
Re: Indy Heads-Boosted Stroker Question [Re: Brian Hafliger] #1510441
10/01/13 09:28 PM
10/01/13 09:28 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Edelbrock victor would make a 1000HP with low boost easy. Spend money on good valvetrain and not on the CNC port work bling . At that power range the Brok and Indys parts are still in the duty range of workability .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Indy Heads-Boosted Stroker Question [Re: Slingshot383] #1510442
10/01/13 09:59 PM
10/01/13 09:59 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
You can't use the 572-13 head on a 4.375 bore block ! It will need clearanced for the larger valve ! You will then shroud the valve ! They are suited more for the larger bore blocks! Any of the heads you listed would work good for a boosted stroker ! I would lean more towards the -1s or the victors !
Re: Indy Heads-Boosted Stroker Question [Re: go green] #1510443
10/01/13 10:19 PM
10/01/13 10:19 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am using the edel victor with a std port opening,HS rockers,Manton pr.
Re: Indy Heads-Boosted Stroker Question [Re: dart69bigblock] #1510444
10/01/13 10:26 PM
10/01/13 10:26 PM
AndyF Offline
AndyF  Offline
Hot Rod magazine did a blown 1400 hp low deck 451 a few years back. They used a stock block, 440Source crankshaft and unported Victor heads. Why don't you just copy their build?
Re: Indy Heads-Boosted Stroker Question [Re: Brian Hafliger] #1510445
10/03/13 12:32 AM
10/03/13 12:32 AM
Omaha, NE
Omaha, NE
Chris
Brian
Hood clearance won't be an issue. I will work around whatever setup I end up with.
Re: Indy Heads-Boosted Stroker Question [Re: dart69bigblock] #1510446
10/03/13 01:15 AM
10/03/13 01:15 AM
SoCal
SoCal
Chris
Brian
I think I would go with the -1 heads personally but if you don't want a lot of rocker offset, the SR's will work great too.
Brian Hafliger
Re: Indy Heads-Boosted Stroker Question [Re: dvw] #1510447
10/03/13 06:45 AM
10/03/13 06:45 AM
gregsdart Offline
gregsdart  Offline
Doug
I think it is easy to look at a boosted application in the wrong light. Boosted, is nothing more than an artificial good air day. A few pounds boost is about like going from Albuquerque on a very hot day (8,000 ft, probably 10,000 DA?) to mine shaft air Like the east coast gets spring and fall. The laws of physics just don't change. The air gets denser, that is all. It still reacts to head flow in the same way. Pick the heads accordingly. If the motor built will make 400 hp normally aspirated, then doubling the air (doubling air density, not boost) going in will at least double the power. The engine friction doesn't go up as much, so the percentage of gain can actually be more than the added air. As the air inlet temp rises, it loses density for the same boost, so AIT is very important.
As far as the EZ heads versus a standard port , the higher the boost, needs a bit less exhaust port percentage due to the higher pressures at the valve opening event.
Re: Indy Heads-Boosted Stroker Question [Re: dart69bigblock] #1510448
10/03/13 04:02 PM
10/03/13 04:02 PM
I'm not sure at what power and tuning level the Mopar 400 production low deck blocks will fail at, are you going to use a stock 400 low deck block for this build? IF so what blower are you planning on using? Are you going to use a intercooler? The reason I'm asking is I have built,assembeld and dyno tuned several roots blown motors on pump gas and race gas, carbs and EFI. Manifold air inlet temps are critical on tuning a blown gas motor at WOT, the more pressure you build the more heat is created under the roots type blowers My message is it is, in my mind and opinion, way better to use a 10.71 and spin it at 12% underdriven to make 7 lbs of boost than it is to use a 6:71 and spin it at 12% overdrive to make the same amount of 7 lbs boost The IAT on the bigger, slower spinning blower, may be from 80 to 150 F cooler than with the smaller, higher spinning blower Also I would be very hesistant to use a stock 400 Mopar block at that power level, even with good main caps and studs, the cylinder walls will be the weak link in my opinion
Re: Indy Heads-Boosted Stroker Question [Re: Cab_Burge] #1510449
10/03/13 05:47 PM
10/03/13 05:47 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I agree with Mr Cab on the stock block.Indy makes a Maxx aluminum low deck block,it use's the std 440 crank mains,and dist.,4.50 block and the 572-13 heads fit on it.You can make 528 cu in 4.50 bore & 4.15 crank or 540 cu in 4.50 bore X 4.25 crank with the Low Deck maxx aluminum block.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy Heads-Boosted Stroker Question [Re: MRMOPAR622] #1510450
10/03/13 08:45 PM
10/03/13 08:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What about a water/meth combo to lower the IAT's.What I read about Snow & IAS seems too good to be true
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Indy Heads-Boosted Stroker Question [Re: hemi-itis] #1510451
10/03/13 08:53 PM
10/03/13 08:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How fast do you want to go? Build accordingly. Anything quicker than 10.0 needs chassis cert,license,traction aids,etc. Is it a race car or street car? I guarantee a 10.0 street car on 275 radials is a hand full. Do you need a 20K motor with another 8k worth of chassis and saftey stuff? Maybe yes, so go for it. But don't do it just to blast around on the street, You don't need it.
Doug
