top & second ring end gap #1510067
09/30/13 04:53 PM
09/30/13 04:53 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
KB Icon forged pistons and 1/16" iron ring set. Drag Supercharged or Nitros application. - and your suggestion is ??? Thanks, John
Fastest 300
Re: top & second ring end gap [Re: Crizila] #1510068
09/30/13 05:03 PM
09/30/13 05:03 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
iron ring set? as in stock cast iron rings in a power adder engine?
either way bore size is critical with regards to end gap, you need to post that
Re: top & second ring end gap [Re: jamesc] #1510069
09/30/13 06:27 PM
09/30/13 06:27 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Bore is 4.030. Top ring is moly filled.
Fastest 300
Re: top & second ring end gap [Re: Crizila] #1510070
09/30/13 06:56 PM
09/30/13 06:56 PM
jamesc Offline
jamesc  Offline
speed pro recommendations are .006" per inch of bore (.024" for a 4.03" bore) for supercharged applications and .007" (.028" for a 4.03" bore) per inch of bore for nitrous applications.
they normally are using wider second ring gaps to bleed off pressure to keep from unseating the top ring but in this case they're listing the top and second the same. either way they're using wider second gaps these days as opposed to tighter which was practice for many years.
remember when it comes to ring gap too much is better than too little, butt the ring ends and bad things happen
Re: top & second ring end gap [Re: jamesc] #1510071
09/30/13 07:04 PM
09/30/13 07:04 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ok, Thanks Jim!
Fastest 300
Re: top & second ring end gap [Re: jamesc] #1510072
09/30/13 08:41 PM
09/30/13 08:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
looser is better, unlike some other things in life
Re: top & second ring end gap [Re: jamesc] #1510073
09/30/13 10:02 PM
09/30/13 10:02 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
x3
