Re: Who runs a diaper on their race car
[Re: bigtimeauto]
#1510009
10/03/13 09:44 PM
10/03/13 09:44 PM
Posts: 1,770 Pa
Wv68charger
Pa
Considering the pan over the blanket, do you use specific mats in your pan bigtimeauto? Ever heard of pig mats? Trying to decide on a oil pan which will dictate wether we go blanket or pan.
right above your post I posted I use 3 pig matts LOL I silicone them in.
LOL missed that... So I'm on an apple device and can't access your website I'm assuming you make pans?
[Re: VernMotor]
#1510013
10/03/13 09:52 PM
10/03/13 09:52 PM
Posts: 1,770 Pa
Wv68charger
Pa
well we here in farmville have lot of farm stores and farmer hardware stores. I will have to check them out
I can get them at work by the roll
Now just have to make a decision....
[Re: VernMotor]
#1510017
10/03/13 11:05 PM
10/03/13 11:05 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
rules
1:8 LOWER ENGINE CONTAINMENT DEVICE In classes where specified, must utilize an NHRA-accepted lower engine oil-retention device. SFI Spec 7.1 or 7.2 Lower Engine Containment Device permitted. A properly fitting lower engine ballistic/restraint device mandatory. The NHRA Technical staff can accept or reject any device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the Technical staff prior to any furthur runs. When used, an SFI Spec 7.1 or 7.2 Lower Engine Containment Device must cover the sides of the block and pan up to within one inch of the head mating surface and extend to within 1 1/2 inches of the front and rear of the cylinder case area. SFI Spec 7.1 devices must be updated/recertified by the original manufacturer at one-year intervals. In classes where specified, a belly pan may be used in lieu of a device attached to the engine. The belly pan must extend from framerail to framerail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides unless specified in Class Requirements. Minimum number of slots or holes in the walls to clear frame, steering, or lines permitted. A nonflammable, oilabsorbent liner mandatory inside of retention device.
[Re: VernMotor]
#1510018
10/04/13 12:13 AM
10/04/13 12:13 AM
Posts: 2,151 Fancy Farm Ky
wyoming
Fancy Farm Ky
Your looking to hard there Vern, unless your planning on stepping way up in class, the retention blanket doesnt have to be SFI, it just has to be NHRA approved, I ran one for about 3 years since the Salt Lake City track required it on any car faster than 10.99, there are several people who will make one fairly resonable. I had a Russler brand the bottom was ok, fit well the straps were kinda chincy, thats been well discussed on here, but a custom made one for fit was a little under $200, I ruined mine on a very rough track, right after I mover here, Marion County up in Ohio will make you hit the brakes a little hard in the shutdown area, anyway I scrapped the bottom on mine.NHRA has a list of ones that are accepted, they just got a little cash from those guys, SFI would have cost them more for sure
[Re: Dads426]
#1510022
12/04/13 09:52 PM
12/04/13 09:52 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
Someone wanted pics of the custom diaper, so here they are:
So where does that attach up the block? And how in the hell do you change the oil?
