Re: made some headway on my 60' [Re: mopar dave] #1509886
10/01/13 02:06 PM
10/01/13 02:06 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
what did you end up with for shock settings? sunday I was pulling front tires about 4-5" and carrying them about 12".
Dave I just watched your video a bunch of times. You need more front end travel. If you have torsion bars turn them down. 2 inches more of travel would make a big difference.
I am turning mine down more for my next trip the the track but I only have about 1 more inch travel available before I'm hitting the bump stops.
Re: made some headway on my 60' [Re: DodgeCharger] #1509887
10/01/13 02:12 PM
10/01/13 02:12 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I may be able to drop an inch,but that would be all. I have 5" of front travel right now.
Re: made some headway on my 60' [Re: DodgeCharger] #1509888
10/01/13 02:12 PM
10/01/13 02:12 PM
PA
ajcasini Offline
ajcasini  Offline
PA
8 extension
7 Rebound
Re: made some headway on my 60' [Re: ajcasini] #1509889
10/01/13 02:14 PM
10/01/13 02:14 PM
Mt Morris Michigan
Mt Morris Michigan
thanks. i'll look into getting some of those over the off season.
Re: made some headway on my 60' [Re: mopar dave] #1509890
10/01/13 08:13 PM
10/01/13 08:13 PM
Mohnton, Pa
Mohnton, Pa
Five inches should be good. I think Calvert recomends a minimum of 5.
Re: made some headway on my 60' [Re: DodgeCharger] #1509891
10/01/13 11:35 PM
10/01/13 11:35 PM
Mt Morris Michigan
Mt Morris Michigan
heres a vid from a better angle. bars in upper hole on this run.
http://youtu.be/Y4qbG48xPxE
Re: made some headway on my 60' [Re: FlyFish] #1509892
10/02/13 09:36 AM
10/02/13 09:36 AM
Mt Morris Michigan
Mt Morris Michigan
congrats on your improved 60. if your using QTP's 18+ on tire pressure and shocks softer 5 according to Alex@moneymakerracing. i'll give it a try next time out.
