Rear end / ladder bar question #1509589
09/29/13 02:19 PM
09/29/13 02:19 PM
HR3128 Offline OP
HR3128  Offline OP
I got this 9" Ford set-up last week-end. It's 36" flange-to-flange & 18.5" Outside-to-outside on the ladder-bar mounts. Is it to narrow to use in a 71 B-body? Ladder-bar spacing to close together?
Re: Rear end / ladder bar question [Re: HR3128] #1509590
09/29/13 09:08 PM
09/29/13 09:08 PM
Measure the insides of your rear sub frames and find out the worst thing that can happen is you need to order another front ladder bar mounting kit and have it welded in
Re: Rear end / ladder bar question [Re: Cab_Burge] #1509591
09/30/13 10:01 AM
09/30/13 10:01 AM
HR3128 Offline OP
HR3128  Offline OP
Are the ladder bar mounts to narrow for a big car? Would it be more stable with the ladder bar & shock mounts further apart?
Re: Rear end / ladder bar question [Re: HR3128] #1509592
09/30/13 01:05 PM
09/30/13 01:05 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
It would be more stable with a wishbone over the diagonal. If you make a lot of power, you might bend or break the diagonal, seen it happen before.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
