Another Disc Brake Converstion Question #1509551
09/29/13 01:37 PM
09/29/13 01:37 PM
Indy
N
Nuke463 Offline OP
Nuke463  Offline OP
N
Indy
Hello all! I have read all the info about the disc brake conversion info but I still have an issue I can't figure it out. I have a 71 Charger. I am using spindles from a late 72 Charger to which I added the larger 11.75 Cordoba rotors. No problem there. I Picked up the larger Cordoba caliber adapters however, they will not bolt up to the spindles. The original adapters that came with the 72 spindles I am using are the smaller ones that accept the smaller 10.95" rotors. I am stumped. Do I need different spindles? Help!
Nuke
Re: Another Disc Brake Converstion Question [Re: Nuke463] #1509552
09/29/13 02:52 PM
09/29/13 02:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe it's the 73 and up spindles you need, not the 72's.
Don't be the exception.
Re: Another Disc Brake Converstion Question [Re: Nuke463] #1509553
09/29/13 04:39 PM
09/29/13 04:39 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Are you sure you have Cordoba 11.75" caliper brackets? The bolt pattern is the same for all 1970 and newer B/E/F/M/J/R body disc knuckles
Re: Another Disc Brake Converstion Question [Re: DoctorDiff] #1509554
09/29/13 08:02 PM
09/29/13 08:02 PM
Indy
N
Nuke463 Offline OP
Nuke463  Offline OP
N
Indy
Cass,Yes. I took them off the Cordoba myself in the junk yard. That's what I can't figure out. The Cordoba adapters will not fit on the 72 spindles..
Nuke
Re: Another Disc Brake Converstion Question [Re: Nuke463] #1509555
09/29/13 08:25 PM
09/29/13 08:25 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I swapped those parts many times.
What doesn't fit? Does the bolt pattern on the knuckle match the bolt pattern on the caliper bracket?
Can you post pictures of the parts?
Re: Another Disc Brake Converstion Question [Re: DoctorDiff] #1509556
09/29/13 08:26 PM
09/29/13 08:26 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
If your brackets don't fit, (too big) then your trying to put "C" Body brackets onto the spindles.
That ain't gonna happen.
Spacing is different.
Maybe somebody changed stuff on the Cordoba, that you say you got the brackets off of.
What brackets are you trying to use?
Pin type, or Slider type?
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Another Disc Brake Converstion Question [Re: hemi71x] #1509557
09/29/13 10:05 PM
09/29/13 10:05 PM
Indy
N
Nuke463 Offline OP
Nuke463  Offline OP
N
Indy
The bolt pattern is different. The 'spread' for the holes on the slider adapters are greater than the spread on the holes on the spindle. I am a positive that nothing was altered on the Cordoba from the yard. Again, the Cordoba rotors fit fine.
Re: Another Disc Brake Converstion Question [Re: Nuke463] #1509558
09/29/13 10:13 PM
09/29/13 10:13 PM
Well then, the only thing that i can tell you is someone put "C" body brakes on that Cordoba.
Who knows what could have been done to an old car throught the years.
Your options are.
1. Find another car with the proper adapters.
2. I can sell you a pair of the taller sliders.
3. DrDiff can sell you a pair too.
Re: Another Disc Brake Converstion Question [Re: Nuke463] #1509559
09/29/13 10:16 PM
09/29/13 10:16 PM
Measure (& post) what you have for C to C on the bolt holes in those adapters
