Re: Edelbrock Torker 440 fit?
[Re: 70satelliteguy]
#1509088
09/28/13 04:50 PM
09/28/13 04:50 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I know that that same combo would not fit under the hood of my '68 Coronet. From what I have been told the Edelbrock Performer RPM will make as much and more power than the Torker and I think it is shorter. If I were you I would go to the Edelbrock catalog and look up the dimensions that should be there before I made a decision either way. The Torker is fine if you already have it, you will just have to work with it.
Now that I think of it, I may have compromised the height issue with a spacer...after all it was only 30 years ago!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: RUNCHARGER]
#1509090
09/28/13 05:13 PM
09/28/13 05:13 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks for the replys "Is it a Torker or a Torker 2. I don't know about the 2." It is an original swap meet 440 Torker Thanks Mike
[Re: Mr.Yuck]
#1509096
09/30/13 11:39 AM
09/30/13 11:39 AM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks for all of the reply's I am glad it will fit and I plan on using about a 3000 stall converter anyway so I am not too worried about it being a single plane. I ran one years ago on a 440 with a MP 557 cam and it worked pretty good! This has a custom Comp 502/273intake and 511/279 and will have a sure grip 3.23 rear. Mike
