Re: A-727 DEEP PAN GASKET?
[Re: Hot 340]
#1509051
09/28/13 06:36 PM
09/28/13 06:36 PM
Posts: 30,447 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
My opinion is the gasket isnt as critical as the pan. I just put a new summit aluminum pan on mine and used the cheapy paper gasket drove it for a couple hrs last nite and its dry as a bone. Your results may vary. Just leave out the rtv. But if its steel, definitely the reusable mopar gasket.
THERE you go ... if the pan-rail is flat ... a cheapO cork should work fine !!
[Re: dOoC]
#1509052
09/28/13 06:51 PM
09/28/13 06:51 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I just used the cheapo cork one with my stock steel pan, because I already had it and the the stores were closed. Used some of the red spray tack, no leaks here...BUT I would have preferred a steel/rubber
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dusturbd340W5]
#1509056
09/28/13 10:47 PM
09/28/13 10:47 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
My experience has been this..... CAST aluminum pan : you can use the 2464324AC re-usable gasket. ANY steel stamped pan: use the cork/rubber impregnated gasket if the pan rails are straight.. I know some of you guys will cry BS, but I've had a FEW leakers and I'll stick to what I say. Nothing worse than a leaky pan after the blanket's on there...makes a messy scene.
[Re: J_BODY]
#1509058
09/29/13 01:18 AM
09/29/13 01:18 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I had never heard of the factory steel shim gasket til recently so I put one on my Duster with a deep steel pan. I used to always use good cast aluminum pans so the paper gaskets were fine.
