I ran my 518 C.i. pump gas 400 stroker 6 pak around 13.8 to 15.1 on the AFR at idle and real light throttle cruise up to 2500 RPM or so. It ran between 13.2 to 13.8 AFR at WOT. I like running a cold spark plug and as lean as I can get it to run without peppering the spark plugs, I shoot for 34 BTDC on the timing above 2000 RPM and 14 to 16 BTDC at idle, under 1100 RPM. What cylinder heads, iron or aluminum and fuel are you using. Mine had 10,78 to 1 comp. ratio with the last set of heads on it, I also ran non ethanol 91 octane OR pump fuel in it
it ran a best of 9.96 at 134.+ MPH through the exhaust with the air cleaner on weighing 3400 LBs with me in it
that was with a set of Indy SR M.W. ports and a Indy 400-3 intake and a Holley 1050 Dominator carb., the six pak set up with a set of CNC ported Eddy RPM and the six pak ran 10.01 several times at the same track on different days and weather
Six paks can be made to rock
