Re: 5 on 4" bolt pattern rims
[Re: ProSport]
#1508700
09/28/13 12:08 AM
09/28/13 12:08 AM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I'll see if I can locate ad
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#1508705
09/28/13 10:55 AM
09/28/13 10:55 AM
moparpollack
Lil Herman
Lil Herman
85086
Don't forget most 4.5 disc brake kits move the front wheels out .5" or more.
[Re: moparpollack]
#1508706
09/28/13 11:06 AM
09/28/13 11:06 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Oh yea I know that actually, I'm putting a alerkation under it Wanted to hold off on that until the project hits that spot but, I might just have to step up now If I can find some used 4" centerlines I could mock it up and buy the front when needed Only been waiting to get on table for 13 months this time 3 shop ..
[Re: Rhinodart]
#1508707
09/29/13 01:41 AM
09/29/13 01:41 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I do have a set of Centerline and aluminum slot frontrunners 4" wide laying around.
Where did those come from ???
[Re: imfixinmopars426]
#1508709
09/29/13 10:51 AM
09/29/13 10:51 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
could you re-drill a set of 15x5.5-4.5 pattern wheels just for static use?
Suppose you could ?
already thought about
welding the 4 inch stock center into a 15 inch hoop might can do that too
[Re: bigdad]
#1508710
09/29/13 01:15 PM
09/29/13 01:15 PM
JohnRR
U.S.S.A.
there is a guy in Pa. that does this so it should be easy.
