Re: Need to buy a new carb [Re: BradH] #1508674
09/29/13 04:37 PM
09/29/13 04:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I bought custom Quickfuel carbs for my tunnel ram a few years ago and everything was pretty much dead on out of the box, best carbs by far that I've ever owned.
Re: Need to buy a new carb [Re: ProSport] #1508675
09/29/13 05:25 PM
09/29/13 05:25 PM
ont,canada
mopartuner Offline OP
ont,canada
After work yesterday(got up at 4am)I drove to Summit(6hrs)gave them my 850 ultra and picked up a 850 Quickfuel.Out of the box this thing works better than the Holley.AFR is at about 11.3 so I jetted down by 4 sizes front and rear and we will see how that works.Even fat it has better throttle response than the holley.I got home at 2 am....was a long day.
410 pump gas solis flat tappet cam 10.95 so far
Re: Need to buy a new carb [Re: mopartuner] #1508676
09/29/13 07:04 PM
09/29/13 07:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Good deal! I think you'll be real happy with it. That is definitely a long day, I live just a few blocks from Summit, it is so convenient. I was probably working on the Duster when you were at Summit.
What setup are you using to monitor air/fuel ratio? Do you have an oxygen sensor in each header collector? I've always just tuned at the track for best MPH and ET and just left it there, but this is the first true street car I've ever built so I want it to run safe at highway speeds and stuff like that.
Re: Need to buy a new carb [Re: ProSport] #1508677
09/29/13 08:17 PM
09/29/13 08:17 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
I put a Q series 850 on a healthy 440 w/ alum heads and it ran great out of the box. other than some minor tuning, no problems for 3 years now! good choice.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Need to buy a new carb [Re: ProSport] #1508678
09/29/13 09:22 PM
09/29/13 09:22 PM
ont,canada
ont,canada
I have an AEM wideband witha sensor in only one side,I don't live by it,its just a nice tuning aide
Re: Need to buy a new carb [Re: mopartuner] #1508679
09/30/13 07:27 AM
09/30/13 07:27 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ok thanks.
