Re: Slicks
[Re: rickraw]
#1508385
09/27/13 03:04 PM
09/27/13 03:04 PM
Posts: 861 lancaster,california
johnnycuda
McCormack Racing,1-800-999-DRAG
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Slicks
[Re: rickraw]
#1508387
09/29/13 11:27 PM
09/29/13 11:27 PM
Posts: 1,104 Massillon, Ohio
cudatom
Massillon, Ohio
Check Harlow Racing (800.919.RACE (7223)). They will make sure that the tires match. Something to consider is, as much as you would think that all tires for a specific size would have the same circumferential they dont. They can vary greatly. when I got mine I asked what different measurements they had. The guy I talked with(cant remember his name now)said he would check and call back. About a 1/4 to 1/2 hr later he called back and gave me the measurements of 6 different matched sets. There was a good 4" of difference between the smallest set and the largest. Very helpful people. Wish they were still at Norwalk but I knew when Summit took over that Harlow would be out.
Ok
Re: Slicks
[Re: rickraw]
#1508390
09/30/13 06:46 PM
09/30/13 06:46 PM
Posts: 914 tn
robnbird
tn
Anyone know has the best price's on slicks. Thanks 4 ur time.
Jegs is in your back door use them...
