the lower 1/2 of steering colum is shorter for the power steer box with any colum.
basic bolt up the same. but tilt has special plugs/adaptors for the wireharness. it is based off a GM tilt colum when looking for "how too" and "parts" for them.
watch yrs for gear selct indicater hook up on the colum, some on the colum/some in the dash gauge cluster and wipers/turn sig move to colum in mid 80s. correct dash harness is needed.
I guess you can hack the wires for hook up? I know I have.
some have rag joints both ends/ some have a rag joint with a pot coupler at the box end, those have to be matched up going from manaul to power on the shorter shaft.
a " Borg" shaft is a good upgrade for the lower 1/2 of the colum on all of the doge trucks as well as the steering box frame support bracket found on mid 80s trucks.
