Header bolt coolant
#1507800
09/26/13 12:37 AM
09/26/13 12:37 AM
Posts: 123 Elizabethton Tn
louie heaton
Elizabethton Tn
Whats the best thing to put on header bolts on a big block, to keep the coolant from leaking, I guess you have to put it on both sides, I know the drivers side goes into water jacket.
70 T/A clone, Hensley built 440,(not much more than stock) Low 12's at Bristol,(17 miles from here)8 other various Mopars, used to have 800+ posts back around 2001.
Re: Header bolt coolant
[Re: a12superbee]
#1507805
09/26/13 10:31 AM
09/26/13 10:31 AM
RapidRobert
I also vote for the OE studs with the shoulder in the middle. Shorten the outer fine threaded portion till only enough threads remain for the nut to fit flush. any more than that greatly hampers fitment & is a waste & you can also use a high grade nut that is thinner so you can shorten it even further
[Re: a12superbee]
#1507807
09/26/13 12:05 PM
09/26/13 12:05 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Leave the studs in, use nuts.
Only way to fly. The guy that did my motor convinced me to do that, I can't believe how many years I spent jacking around with those stupid bolts.
Especially if you have to pull the header to do a starter change and it requires draining the cooling system
[Re: RapidRobert]
#1507808
09/26/13 12:08 PM
09/26/13 12:08 PM
JohnRR
I like to have a thread or 2 sticking out past any nut on anything I am assembling . .031 shouldn't be that big a deal unless you are trying to shave off every last gram of weight ...
