Re: Transmission speedometer gear?
[Re: Mopar_Ray]
#1507598
09/25/13 06:06 PM
09/25/13 06:06 PM
Posts: 26,051 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The adaptor has an O rig sealing it to the tailhousing and a lip seal that seals the pinion shaft.
The builder probably told you to leave it in because he didn't have the correct 1 49/64" soft plug to seal the hole.
[Re: John_Kunkel]
#1507599
09/25/13 06:39 PM
09/25/13 06:39 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
I called builder, He said it flinged oil to the tail housing?
[Re: Mopar_Ray]
#1507600
09/25/13 07:04 PM
09/25/13 07:04 PM
Posts: 75,136 A Banana Republic near you.
JohnRR
If John K. says it can be plugged with the proper size plug then I would believe it.
Do you have the speedo connection capped ?
You can pull it and replace the seals or pull it and plug the hole, your choice.
[Re: scratchnfotraction]
#1507602
09/26/13 01:20 AM
09/26/13 01:20 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I had a machinist fried turn me a plug out of aluminimum. It looked like the base part of the speedo gear houseing without the center hole. He even grouved it for an O ring and was held in by the factory clamp...
I am truckless..
[Re: 340SHORTY]
#1507603
09/26/13 03:50 PM
09/26/13 03:50 PM
John_Kunkel
Rio Linda, CA
Some folks just remove the gear and thread the hole in the adapter for a tapered pipe plug....go a step further and hacksaw the threaded part of the adapter.
