Stinky interior- how to get rid of mildew? #150742
11/14/08 12:56 AM
11/14/08 12:56 AM
Niwot, CO Formerly denn...
dynorad Offline OP
dynorad  Offline OP
I bought this car for my daughter, but it has been wet inside for an extended period of time. I was thinking bleach. Is there something better?
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150743
11/14/08 01:09 AM
11/14/08 01:09 AM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Wow Nice car, Probably going to have to pull the carpet and see how bad it really is.
Re: Stinky interior- how to get rid of mildew? [Re: copper67440] #150744
11/14/08 01:14 AM
11/14/08 01:14 AM
dynorad Offline OP
dynorad  Offline OP
It has rubber floormats (no carpet). Will be pulling the interior apart and I think that bleach will work OK on the jute backing of the mats. But the underside of the seats and up under the dash the bleach may cause too much damage.
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150745
11/14/08 03:54 AM
11/14/08 03:54 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Simple Green to clean it, then lots of Fabreez
I am truckless..
Re: Stinky interior- how to get rid of mildew? [Re: 340SHORTY] #150746
11/14/08 03:59 AM
11/14/08 03:59 AM
Martin TN
ridin98ci Offline
ridin98ci  Offline
Martin TN
you will need to get the seat covers off too...you can use dryer sheets in there too...good luck.
LOUD AND PROUD!!!
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150747
11/14/08 04:45 AM
11/14/08 04:45 AM
FJ5 Acres, Colorado
Stage-III Offline
Stage-III  Offline
FJ5 Acres, Colorado
Hi Dennis,
Been a long time since I talked to you... Hope all is well.
I've also had success with vinegar. Put a pie pan or two of it under the seat, roll up the windows and let it sit in the sun for a couple of days to kill the mold spores. The interior will stink like vinegar, but that's easy to dissipate compared to the mold. I have done that for what I consider mild mildew in this dry climate, so YMMV.
Nice looking Valiant, BTW!
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150748
11/14/08 04:54 AM
11/14/08 04:54 AM
None
71rm23 Offline
71rm23  Offline
None
The question I have is: How did it get wet in the first place?
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150749
11/14/08 10:29 AM
11/14/08 10:29 AM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
When you pull the interior out you can wash all the metal and some of the hard plastic with the bleach, but I would be very care full on plastic and vinyl and bleach.
Look around at the big box building stores, they have lots of safer methods then bleach for fabrics.
There is a product at the Home depot we use in my biz and it is called mold control.
It kills and seals mold, it has worked for us and has been passed by building inspectors.
Try it, it can't hurt like bleach will.
I used Mr clean on the hard fabrics like seat belts and stuff with lots and lots of vacuuming, then the mold control on the carpet both sides.
It worked pretty good for the time I owned the car. Head liner is the toughest part, easy to stretch or tear if your not careful.
Re: Stinky interior- how to get rid of mildew? [Re: boydsdodge] #150750
11/14/08 09:05 PM
11/14/08 09:05 PM
dynorad Offline OP
dynorad  Offline OP
Thanks for the suggestions. It got wet either by leaks around the windshield or through the wiper pivots. I will be doing the hose test to see what's what. I can hardly stand to be in there after being exposed for 10-15 minutes.
Hey Dave- hope you are OK too.
Re: Stinky interior- how to get rid of mildew? [Re: dynorad] #150751
11/14/08 10:22 PM
11/14/08 10:22 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Jute backing is relatively cheap--I think just replacing it would get much better results
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
