crank shaft register and converter
#1506822
09/24/13 10:09 AM
09/24/13 10:09 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
My new convertor for the cart is about .002 larger than the Crank register. It looks as though I should be able to clean it up and make it work without shipping a converter back. Tootsie roll the crank register a bit? I mean it will fit but its Tight. ![](/ubbthreads/images/graemlins/shock.gif) And not in the good way! ![](/ubbthreads/images/graemlins/biggrin.gif)
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: crank shaft register and converter
[Re: BB65Barracuda]
#1506824
09/24/13 11:19 AM
09/24/13 11:19 AM
Posts: 75,136 A Banana Republic near you.
JohnRR
I would not tootise roll the crank register , but that's just me.
the big question is what part is the wrong size , the crank or the convertor ?
[Re: BB65Barracuda]
#1506826
09/24/13 02:46 PM
09/24/13 02:46 PM
Posts: 43,375 Bend,OR USA
Cab_Burge
What motor and crank, stock or stroker, are you having the troubles with?
[Re: BB65Barracuda]
#1506827
09/24/13 03:47 PM
09/24/13 03:47 PM
Posts: 26,051 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Unless it's a brand new aftermarket crank, it likely was mated to a converter before so the register isn't the problem.
