Page 1 of 4 1 2 3 4
Running a very low compression Engine on race fuel #1505925
09/22/13 09:04 PM
09/22/13 09:04 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Another thread made me curious about this.
What would be the effect performance wise by running110 race fuel on a 9.5 compression aluminum headed 360?
I have had many arguements with this guy( who doesn't post or read here) telling him his car would probably run better and more consistant if he ditched the race fuel.
He insists on running it because he likes the smell of race fuel.
Is it hurting his ET slip at all to run the stuff?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505926
09/22/13 09:10 PM
09/22/13 09:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I started on 112 octane and changed to 110.. that was
all I changed and the car went quicker and faster..
he could be quicker on moose pee fuel(87 octane)
Re: Running a very low compression Engine on race fuel [Re: MR_P_BODY] #1505927
09/22/13 09:13 PM
09/22/13 09:13 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have always went slower on straight 110 vs 93 when I had 10.5:1.
Re: Running a very low compression Engine on race fuel [Re: MR_P_BODY] #1505928
09/22/13 09:18 PM
09/22/13 09:18 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I have been stumped for a while about this car. Ran quite decent considering the low compression and race gas. He wanted to go faster so I suggested he yank the stock eddies off and get them ported
He did( and by someone who has done plenty of them with proven results) and the car has struggled to run even close to as well as it did before. I suspect the compression is even lower now than it was and the race fuel has had even more negative effect
1.41 best 60 foot
6.56 at 104.17
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505929
09/22/13 09:35 PM
09/22/13 09:35 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Why in the world wouldn't he go make a couple runs on 93 octane? He could even put a dash of grape fuel fragrance from Summit, smells like race fuel, I've used it a couple times for car shows and car cruises.
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505930
09/22/13 09:47 PM
09/22/13 09:47 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
race fuel burns at a slower rate than pump. I use 110 in a 12.5 -1 hemi 114 or 116 slows it down
home of the
Sox and Martin Hemi Duster
Re: Running a very low compression Engine on race fuel [Re: ProSport] #1505931
09/22/13 09:56 PM
09/22/13 09:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No it does not smell any where close to real race gas. I use the stuff too some times, the stuff from summit is weak. Even the good stuff don't smell like race fuel.
I have ran 110 leaded race gas in a 10.5-1 340 since 1983.
Then I switched to 92 octane about 6 years ago because I drive my car a lot now a days and I can't afford race gas even though I sell it at work. And I'm here to tell you the race gas runs way better in in a low compression motor and cooler.
Plus I have ran straight race gas in in dirt bikes, jets skis, chain saws, weedeaters, 2 stroke dirt bikes love it, generators and many other motors and they all ran much better on race gas. I would mix it half and half with 91 unleaded most of the time, because full strength is not always needed. But I have burned a bunch of it straight and it won't hurt even the weakest motor.
I have been on camping trips to the lake, we ride jet ski/ wave runners during the day and dirt bikes at night. I would bring plenty of mixed race fuel for our 2 stroke dirt bikes.. I would always provide some gas for the jet skis and everyone and I mean everyone would be fired up how good there jet skis ran with it. To the point that I sell lot's of race gas to bike and water craft people now a days.
Everything runs better on race gas, I'm sure.
My 71 stock 340 sure as hell does run better with race gas.
I ran straight race gas in a 87 dodge ramcharger with a 360 quradrajet carb at graval rama here in town and my truck ran the quickest on straight race gas at the 300' sand drags. Then I ran the same ramcharger on race gas and nitrous oxide and it ran 14.20 in the quarter on asphalt with stock 360. I have done plenty of back to back testing years ago to see if it really did help and it always helped. Time clocks don't lie.
Re: Running a very low compression Engine on race fuel [Re: ProSport] #1505932
09/22/13 09:56 PM
09/22/13 09:56 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
It's my little brother... He won't listen to anything I tell him.
Most of the time he just likes firing it up in his garage, rapping on the gas pedal, and sniffing race gas fumes.... Would be sad if it wasn't true
1.41 best 60 foot
6.56 at 104.17
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505933
09/22/13 10:15 PM
09/22/13 10:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Are we talking about 93 Race gas or street E10 93? Because I might suspect street E10 93 might be slower then race 110. However FWIW street 93 normally has less BTU's then 87, and those are what push the pistons.
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505934
09/22/13 10:19 PM
09/22/13 10:19 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
My dart went slower with 100oct then it did when i ran sunoco 93 pumpgas.
Re: Running a very low compression Engine on race fuel [Re: fishy340] #1505935
09/22/13 10:52 PM
09/22/13 10:52 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
The thing about 110 race gas is because it burns so much slower, you got to start lighting it sooner. If the car is tuned correctly on pump gas, then you switch to race fuel and do not change anything else, it probably will slow down. Now put race gas in it AND put some more timing into it, then it should respond nicely. Octane can cover up a few tuning "sins" also.
Brian
Re: Running a very low compression Engine on race fuel [Re: '72CudaRacer] #1505936
09/22/13 11:15 PM
09/22/13 11:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
First off... Running more octane than the engine needs is a waste of money.
I tend to run only enough octane to keep it out of detonation with a crisp tune up.
Second, when I raced motorcycles there were all sorts of guys in spec classes that would run sunoco 110, etc in the bikes. Got their rears kicked by a bike running 91-93 from the local cheap circle K pump! The bikes didn't need the octane. I schooled bunches of them on long straights where 2-3hp was a BIG deal.
I'd test it with pump gas and see how it reacts.
Re: Running a very low compression Engine on race fuel [Re: Challenger 1] #1505937
09/22/13 11:46 PM
09/22/13 11:46 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Uh yea it actually does smell like the 110 Cam2 in my area.
Not always, I've seen it too many times where a low compression motor ran better on 93 octane, even with tuning. But if someone says their car would be quicker if they used cheaper gas I'd say prove it!
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505938
09/22/13 11:56 PM
09/22/13 11:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The smell of Cam 2 is very addictive, there is nothing wrong with your brother just because he likes to fire up the motor to get his cam2 fix,I have done it before and I am ok.
Re: Running a very low compression Engine on race fuel [Re: dartman366] #1505939
09/23/13 02:35 AM
09/23/13 02:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I,d get a second opinion
Re: Running a very low compression Engine on race fuel [Re: bonefish] #1505940
09/23/13 03:47 AM
09/23/13 03:47 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've seen it proven on a chassis dyno many times, race fuel is a waste of money if your motor doesn't have the compression to need it.
My own slow junk would slow down .2 on 100 compared to 93 pump swill.
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505941
09/23/13 09:06 AM
09/23/13 09:06 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Is he only running 110? That's a waste of $$$$. As mentioned I guess it can go either way. Maybe he can run more advance? I know my old 95 Dakoda sport ran better w/ 2.5 gallons of 104 mixed w/ 5-6 gal of 93. I run 93 in this 11.2:1 440-6, of course I also run meth/h2o injection. If he likes the smell he can always run a mix.. maybe 1 gallon per 6 of 93.
Coming soon!!!!
Re: Running a very low compression Engine on race fuel [Re: Mr.Yuck] #1505942
09/23/13 10:39 AM
09/23/13 10:39 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It doesn't take a lot of mix to keep that fragrant aroma and you also get a bit of detonation protection.
I would use the last season's left overs in what ever was closest.......lawn mower , snow blower , motorhome , pick up truck.
Even a gallon to 10 - 12 will give you the sweet smell of success.
Re: Running a very low compression Engine on race fuel [Re: B3422W5] #1505943
09/23/13 10:57 AM
09/23/13 10:57 AM
Az
Crizila Offline
Crizila  Offline
Az
Go to ProSystems carbs web sight - "under the scoop" - "how to choose an octane".
Fastest 300
Re: Running a very low compression Engine on race fuel [Re: tubtar] #1505944
09/23/13 11:02 AM
09/23/13 11:02 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
It barely takes any to get the smell
Page 1 of 4 1 2 3 4
