Will a magnum oil pan work on a LA 360? #1505326
09/21/13 10:42 AM
09/21/13 10:42 AM
St. John's Newfoundland
440newport Offline OP
I need a truck oil pan for a LA 360. I have access to a few newer 360 magnum trucks, but will the pan from one of those fit an LA style timing cover?
Or does a magnum pan only fit a magnum cover?
Re: Will a magnum oil pan work on a LA 360? [Re: 440newport] #1505327
09/21/13 01:42 PM
09/21/13 01:42 PM
Andrewh Offline
Andrewh  Offline
I can't say for sure, but I used an la pan on a mag and it bolted up just fine. can't see why it wouldn't work the other way.
the only catch is the gasket had to match the pan.
at least going the la pan on a mag, it would leave a gap.
would guess the la gasket with a mag pan would be too much gasket.
Re: Will a magnum oil pan work on a LA 360? [Re: Andrewh] #1505328
09/21/13 02:02 PM
09/21/13 02:02 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
magnum 360 pan will work use magnum oil pan gasket
