wilwood 4 piston brake Which Master Cylinder 15/16?
#1505281
09/21/13 09:08 AM
09/21/13 09:08 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
I had some brake issues and need a new Master Cylinder.
I have the wilwood 4 piston front disks and stock drum rears. There is also a prop valve for the back.
would the 15/16 bore be the correct size?
I am having a difficult time finding a vehicle that can with a 15/16 bore, 2 bolt Master cylinder. Everything seems to be 1 1/32.
Any ideas which vehicle it may come from?
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: wilwood 4 piston brake Which Master Cylinder 15/16?
[Re: Kam*Kuda]
#1505282
09/21/13 10:22 AM
09/21/13 10:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its gonna make a difference on what your pedal ratio is also.... check for a Dakota master.... I usually just ask to see their books and look up for size then see what it fits
[Re: Kam*Kuda]
#1505283
09/21/13 10:30 AM
09/21/13 10:30 AM
Posts: 9,986 MI, usa
dvw
MI, usa
Make sure you find the correct size first. Go here, it will tell you everything you need to know.
http://www.markwilliams.com/braketech.aspx
Doug
[Re: DoctorDiff]
#1505286
09/21/13 03:44 PM
09/21/13 03:44 PM
Posts: 13,228 aZLiViN
J_BODY
aZLiViN
I'm the only source for a 15/16" bore aluminum master cylinders that work with manual brakes.
Unfortunately, I'm waiting for the pistons, so I can assemble another batch.
...and unfortunately I'm waiting for him waiting for the pistons, so he can assemble another batch!
Jay
