big-block oil pain ID #150513
11/13/08 05:30 PM
11/13/08 05:30 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Can anyone ID the oil pan in the center?
The "orange" one on the left is 1970-'71 440HP/6bbl/HEMI B & E-body ...
The "gray primer" one on the right is #187 big block C-body ...
What's the other one?
Re: big-block oil pain ID [Re: 6bblgt] #150514
11/13/08 05:38 PM
11/13/08 05:38 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
the 2 on right look identical except one has paint on it pic looks like it was taken at angle,so it looks like it might look slightly diff.. just my 2 cents
but I could be wrong
Re: big-block oil pain ID [Re: 340dart4spd ] #150515
11/13/08 06:19 PM
11/13/08 06:19 PM
So. Calif.
bbodybill Offline
bbodybill  Offline
So. Calif.
I would guess 62-65 big block(B body) pan... Very similar to 187 but NO numbers stamped into it.
Re: big-block oil pain ID [Re: 340dart4spd ] #150516
11/13/08 06:20 PM
11/13/08 06:20 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Definately 3 different pans. Gray one has a sharper angle on the lower left corner of the sump than the one in the middle. That just one difference. And the sump area is smaller on the gray one. There's other subtle differences as well. Sorry, dunno what the are for tho
Re: big-block oil pain ID [Re: 6bblgt] #150517
11/13/08 06:55 PM
11/13/08 06:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
does the center pan have any baffles ? if not how much deeper is the sump vs. the 187 ?
Re: big-block oil pain ID [Re: JohnRR] #150518
11/13/08 07:48 PM
11/13/08 07:48 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I know what your thinking
Re: big-block oil pain ID [Re: 64dodge572] #150519
11/13/08 11:13 PM
11/13/08 11:13 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Here is a Max wedge pan.
Getting old just means you were smarter than some and luckier than others.
Re: big-block oil pain ID [Re: 64dodge572] #150520
11/14/08 01:12 AM
11/14/08 01:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well then out with it man
Re: big-block oil pain ID [Re: Scott Carl] #150521
11/14/08 01:22 AM
11/14/08 01:22 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Dan that pan (center) reminds me of my early 413 pan. I'll look it over on Friday and post a pic
Re: big-block oil pain ID [Re: JohnRR] #150522
11/14/08 01:49 AM
11/14/08 01:49 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
No baffles and it appears the same depth as the other two.
Re: big-block oil pain ID [Re: 6bblgt] #150523
11/14/08 11:23 AM
11/14/08 11:23 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I've pulled quite a few pre '67(?) big blocks outta c-bodies with that pan; don't know the exact years tho..early '60's up to '66..??
Just about a month ago I got one out of a '66 Newport 383.
The sump is slighly larger & the notch is more angular than the 187/699.
Re: big-block oil pain ID [Re: JohnRR] #150524
11/14/08 11:32 AM
11/14/08 11:32 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
If it had been 1" or so deeper and baffles, 66-9 street hemi
Re: big-block oil pain ID [Re: 64dodge572] #150525
11/14/08 05:55 PM
11/14/08 05:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
but it's NOT
