1968 Dodge 999 paint Butterscotch ? #1504958
09/20/13 01:31 PM
09/20/13 01:31 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Was butterscotch, bahama yellow available on late 68 Dodge or Plymouth cars ? Just wanted a heads up on earliest color was available.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: Beebuzzn] #1504959
09/20/13 02:15 PM
09/20/13 02:15 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I've never seen it pre-'69...
Re: 1968 Dodge 999 paint Butterscotch ? [Re: RSNOMO] #1504960
09/20/13 02:57 PM
09/20/13 02:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Might be a 999 code car painted a color that is very close to Butterscotch. I thought you could get almost any color with a 999 code? Or was it just fleet colors and other colors from other Mopar models?
Need to pull up door sill plates and other stuff to see a non weathered and non manipulated original paint.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: 1968 Dodge 999 paint Butterscotch ? [Re: autoxcuda] #1504961
09/20/13 05:56 PM
09/20/13 05:56 PM
Alabama
BigMoneyLewis Offline
Alabama
Butterscotch first became available in the Spring of '69 .
It was released as a "spring" color along with a handful of other colorful hues. The 999 (3 digit)code was first used on a fender tag in 1970, In '69 we only had 2 digits on the fender tag so , 99 was correct for 69 special order paint.
Greg
gregward@mchsi.com phone 256-852-0955
Re: 1968 Dodge 999 paint Butterscotch ? [Re: BigMoneyLewis] #1504962
09/20/13 06:01 PM
09/20/13 06:01 PM
Alabama
Alabama
Also of note Bahama Yellow or Butterscotch , which re-appeared in 1971 , carries the paint code EL5 . The first digit (E) tells us what year the color was first intruduced . In this case E=MC2 , No , wait a minute...E= 1969 .
Other examples for reference..
D=1968
E=1969
F=1970
G=1971
and so on (skipping I of course).
Greg
Re: 1968 Dodge 999 paint Butterscotch ? [Re: BigMoneyLewis] #1504963
09/20/13 11:00 PM
09/20/13 11:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
..... but "EF8" first appeared as a Charger ONLY color spring of '68 & paint code "6".
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 6bblgt] #1504964
09/21/13 04:08 AM
09/21/13 04:08 AM
western australia
1cuda Offline
1cuda  Offline
western australia
if it was exactly the same formula then it should have been called DF8.
interesting...if it wasn`t the same formula then it is just ef8 like eb5 gb5 kb5 still b5 but different formula and different in color but still b5 blue.
all the best
frank.
getting back to original question-definitely won`t be butterscotch but could be anything from any manufacturer. any pics???
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 1cuda] #1504965
09/21/13 12:09 PM
09/21/13 12:09 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
EE1 is a dark blue in 68
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 1cuda] #1504966
09/21/13 02:26 PM
09/21/13 02:26 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
interesting...
It is & was the same, that's why I posted it - exception to the "RULE".
The 99 or 999 pant codes could be anything. The easiest to figure (& probably convince Chrysler to paint a car back-in-the-day) are the "fleet" colors or those that were reserved for specific car lines (c-body or IMPERIAL color on a b-body) & there are some known cars hat were delivered in primer & whatever you want to call the finish on the B0/L0 '68 Super Stock a-bodies. There are some "pastel pink" '65 Barracudas.
WAG with no additional information - I'd guess the OP's car could be faded "Omaha orange" a known fleet color that a number of performance 1968-'69 a & b-bodies were painted.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: ademon] #1504967
09/21/13 02:35 PM
09/21/13 02:35 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"EE1" isn't a paint CODE it is a paint STYLE for 1968
"E" = paint CODE for "dark blue metallic" in Dodge speak for 1968.
"EE1" = paint STYLE ('68)
~~~~ "E" = roof paint - "dark blue metallic"
~~~~ "E" = body paint - "dark blue metallic"
~~~~ "1" = mono-tone paint STYLE
"EW2" = paint STYLE ('68)
~~~~ "W" = body paint - "white"
~~~~ "2" = two-tone paint STYLE
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 6bblgt] #1504968
09/22/13 01:40 PM
09/22/13 01:40 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Reason for ? is I was going to look at a 68 coronet r/t 4spd car. Last time I saw car it was dark out and it looked to be butterscotch. When I looked at it in the shop yesterday it was a little different and turned out to be (404 SPD build) JJ1 paint as called out by fender tag.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: Beebuzzn] #1504969
09/22/13 02:09 PM
09/22/13 02:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The color (J - "medium gold metallic") looks a little "muddy" in the picture (lights/paint?) - here's my brothers "JJ1" '68 GTX.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 6bblgt] #1504970
09/22/13 02:23 PM
09/22/13 02:23 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Paint color is off and has a lot of dirt / contaminants needs repaint. Putting a post in the wiw with more about car.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 6bblgt] #1504971
09/23/13 11:48 AM
09/23/13 11:48 AM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
interesting...
Is there anything you don't know Dan? LOL I know you've told me this before, but I forgot all about it. Thanks for the refresher.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: KISSAlien] #1504972
09/23/13 12:59 PM
09/23/13 12:59 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
1968 codes are like learning another marque.
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 1cuda] #1504973
09/23/13 01:29 PM
09/23/13 01:29 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
That would be true IF model-year-of-first-use-letter-code-designator was used on Window Stickers, Broadcast sheets or tags in 69. There was no letter code used like DF8...only F8. Had the color been used in 70 or later, then the use DF8 would be appropriate. Remember...'69 was different that the rest of the years as it only used a two character paint code, not three as in previous and following years.
The same thing applies to R4. It was a spring of 68 color carried over to 69.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 69CoronetRT] #1504974
09/23/13 02:22 PM
09/23/13 02:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
but .....
6, F8, EF8 was used 1968, 1969, 1970 for "dark green metallic"/"ivy green metallic"
as was
S, Y2, DY2 was used 1968, 1969, 1970 for "yellow"/"sunfire yellow"
H, Y3, DY3 was used 1968, 1969, 1970 for "light gold"-"cream"/"yellow gold"
R, DR8 was used 1968, 1970 for "burgundy metallic"
WAG, but I'd bet the color pallet was set for 1969 by the time the "spring special '68" colors were selected. (3/R4, 4/Q5, 6/F8)
Re: 1968 Dodge 999 paint Butterscotch ? [Re: 6bblgt] #1504975
12/04/13 09:31 AM
12/04/13 09:31 AM
Germany
fc7_plumcrazy Offline
Germany
Hi Dan,
Q5 used on 1968 cars?
I know that 3,6 (red and green) were introduced.
"L" is the common turquoise in 1968.
I never saw any 1968 in Q5 ?
You got any pics and more info?
Carsten
