3.9 v6 and 5.9 v8, use the same 5 speed? #1504767
09/20/13 12:02 AM
09/20/13 12:02 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I am looking for a 5 speed for my old work truck and found one in a 98 Dakota V6, I am guessing that it would be the nv3500? would it bolt up to my 360?
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: dirt] #1504768
09/20/13 12:25 AM
09/20/13 12:25 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Bolting up and holding up are two different things.
There's a reason that Ma Mopar never put them behind a 360.
If you drive it easy it may last.
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: SNK-EYZ] #1504769
09/20/13 12:30 AM
09/20/13 12:30 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
my 95 Dakota has a factory 318 and 5 speed. I have 177,000 miles on it now with no problems. I but I don't use it very often to pull my car trailer either.
just looking for a way to get overdrive in my 68 dodge pickup, and I don't want an automatic.
I guess the full size trucks with the nv4500 would be better but I have not found one of those yet.
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: dirt] #1504770
09/20/13 05:46 PM
09/20/13 05:46 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
From a 1998, that V6 transmission is likely an AX-15.
Does it have an integral bell housing, or can you separate the gearbox from the bell?
If it's integral, it's an NV3500. If it's a seperate bolt on bell housing, then it's the AX-15.
no way that the AX will ever hold up to a 5.9. Even the 5.2 trucks were too much for the AX15.
if you have an NV3500 though, it will live for awhile behind that 5.9, how much you modify the 5.9 and how you drive it will play a big role though. they were rated for 350 ft lbs from the factory, and the 5.9 made 345.
I had one behind my modified 5.9 for awhile and it did just fine. 285 rwhp and 325 rwtq. so I'm clearly somewhere north of 300 crank hp and 350 crank torque.
I sold the NV3500 to another Dakota guy so I could upgrade to a viper spec T56.
I know another guy who was running deep into the 13s with a supercharged 5.2 on slicks in his 4000 lb Dakota, on his stock NV3500--and he powershifted it routinely at the track. However, I think he finally blew it up here a few weeks ago.
**Photobucket sucks**
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: 70Cuda383] #1504771
09/20/13 08:15 PM
09/20/13 08:15 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
But, to answer your question, Yes, the 3.9 V6 and the 5.9 V8 have the same small block Mopar bell housing as all other small block Mopars. The V6 trans WILL bolt up to the 5.9
question is whether or not its the AX-15 or NV3500, and how long it will live behind the 5.9
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: 70Cuda383] #1504772
09/20/13 09:10 PM
09/20/13 09:10 PM
scratchnfotraction Offline
you have a choise of the a535 5 speed hydro clutch from a v-6 dak or d-100
ax-15 5 speed with it's own 9 bolt/hydro v-6 bell housing.
or the v-6 v-8 3500 5 speed trans different gear ratios and performance levels when JY scoring them.
then you have the NV4500 5 speed V-8 hydro bell kinda a garanny 1st geat with OD 5th gear.
with a v-6 hydro clutch bell you can even run the 833/833OD 4 speeds
you can use the 130 tooth V-6 flywheel/clutch on a 318-5.2 or a 130 tooth 360 external balance flywheel.
the a535 being the lightest duty of the 5 speeds, ax-15-3500-4500 as the HD unit
i am swaping in a hydro clutch system with a 92-v8 bell, NV4500 5 speed in my 85 stepside using the v-6 flywheel and clutch on a 318.
so far i have found the NV4500 5 speed 2x unit i have needs the xmember moved back 2" to bolt up in the 85 frame.
I am also swaping cabs to a 91 shell for the hydro clutch system/pedels. the 87-93 cabs have per-drill holes for the for the hydro system.
going in a 68 truck might need some fabbing for a trans mount but they used a hydro clutch so that part is a plus for a newer bell and/trans swap.
here are some pics to ID the bells & 5 speeds when junkyarding
the v-6 d-100 bell has the hydro slave on pass side.
the d-150/DAK v-8 bell has the hydro slave on driver side.
the v-6 and v-8 hydro bells have 2 trans bot patters to cover 4 75 speed trans.
the ax-15 v-6 bell is a beats of its own with 9 bolts and slave on driver side.
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504773
09/20/13 09:11 PM
09/20/13 09:11 PM
#2 pic
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504774
09/20/13 09:11 PM
09/20/13 09:11 PM
#3
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504775
09/20/13 09:12 PM
09/20/13 09:12 PM
#4
based on a 904 for size and replaced the 833OD 4 speed units
used a 904 spline yoke and a 23 spine input shaft
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504776
09/20/13 09:14 PM
09/20/13 09:14 PM
#5 NV4500 5 speed 92 v-8 bell
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504777
09/20/13 09:42 PM
09/20/13 09:42 PM
#6
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504778
09/20/13 09:44 PM
09/20/13 09:44 PM
#7
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504779
09/20/13 09:45 PM
09/20/13 09:45 PM
#8
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504780
09/20/13 09:51 PM
09/20/13 09:51 PM
#9 this is a ax-15 5 speed
it is a 4x4 unit and a 2x tail housing looks like..well a 2x tail housing.
if you look you can see the bulges on the outside of the trans case around the input shaft end. this is the 9 bolt hydro bell that is specific to the ax-15
when I looked at this 5 speed i dont see how you could hook up an older mech style speedo gear/cable but other than that it would be an ez swap to a SB v-8 using the 9 bolt v-6 bell from a DAK
hope that helps you out some when looking for a 5 speed unit.
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504781
09/20/13 10:01 PM
09/20/13 10:01 PM
you will want to use the newer pilot bearing that fits the TC hug hole and is a roller bearing.
fits all of the SB engines pre-mag and magnum v-6/v-8
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504782
09/20/13 10:01 PM
09/20/13 10:01 PM
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504783
09/20/13 10:03 PM
09/20/13 10:03 PM
i dont seem to have a pic of the nv3500 5 speed
it has the non-removable bell housing
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504784
09/20/13 10:06 PM
09/20/13 10:06 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i think i would use an ax15 for a car or non towing truck.if i was going to tow i would use a 4500
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: d-150] #1504785
09/21/13 12:20 PM
09/21/13 12:20 PM
only bad thing about the NV4500 i have found doing my swap is...the price of the mopar NV4500 gear oil 25.00$ a qrt and needs 6-7 qrts from what the dealer tech said. 200$ fill up with a special synthetic GL-4 gear lube or the carbon fiber syncrhos wont last very long before they need replaced.
Re: 3.9 v6 and 5.9 v8, use the same 5 speed? [Re: scratchnfotraction] #1504786
09/21/13 05:54 PM
09/21/13 05:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
They fit big blocks too!
