Rear Rim BACKSPACE 72 Road Runner, Help
#1504345
09/19/13 12:34 PM
09/19/13 12:34 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Ready to Order a Set of Rear Rallyes for my 72 Clone.
Leaf Springs in Stock location.
Will 15x10 w 5" backspace work? How much tire?
What are you using?
Re: Rear Rim offset 72 Road Runner, Help
[Re: 440PURSUIT]
#1504346
09/20/13 12:05 AM
09/20/13 12:05 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Same car. www.vintagewheelworks.com V45s. 17x8 front. 18x9.5 rear. Not absolutely positive on backspacing other that it was the standard offset offered at the time (they offer two different offsets on that rim now). Pretty sure it is 5.5" backspacing. Tire is 275/40-18. (Should have gotten bigger tire - 285/45-18, but it wasn't offered in that brand/model tire.) 1" clearance to spring on passenger side. 1-1/8" clearance to spring on driver side. Factory spring location. Plenty of clearance on fender, but the lip is rolled.
[Re: 440PURSUIT]
#1504347
09/20/13 10:03 AM
09/20/13 10:03 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
What are you using?
Chris I'd think so. I have 15x9" w/ 5" backspace on my charger. Doesn't the 72 have more BS available?
[Re: Mr.Yuck]
#1504348
09/20/13 10:33 AM
09/20/13 10:33 AM
Posts: 12,495 Western Colorado High Desert
moparmarks
5"-5.5" usually works on a 71/2B but I'd measure from the drum flange where the rim sits back to the leaf springs on both sides just to be sure. Also we are talking back spacing, not offset. Two different things. Also be sure to allow for the tire side wall which can vary depending on if your running 15" or 20" rims and tires.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Mr.Yuck]
#1504349
09/20/13 10:35 AM
09/20/13 10:35 AM
moparmarks
Oops, see your running 15" which have more side wall sticking out.
Re: Rear Rim BACKSPACE 72 Road Runner, Help
[Re: 440PURSUIT]
#1504351
09/22/13 07:51 PM
09/22/13 07:51 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Don't take any computor screen generated measurements as gospel...There's just too many variables like spring sag,rear bushings, rear housing accuracy{as in side-to-side} which is never the same on each side... Get{borrow} a wheel, preferably as close to the size you want to add ...Measure the backspace,width on the rim for the initial fitting...See how it fits then you can figure out which way you need to go to center the wheel where you need it...There's going to be a tight side{left or right}to the quarterpanel lip so find it and make sure the wheel/tire combo will clear... Alot of tire manufacturers list the cross section width to help figure the sidewall bulge... It takes some homework but the results are worth it in the end... Here's a pic of a 10 inch rim that fits nicely in the wheelwell of a 73 road runner The tire is a mickey thompson with a 12 inch cross section...I spent alot of time measuring to make sure it was going in there ... ![](http://i46.photobucket.com/albums/f131/Screamindriver/passshot.jpg)
