Transmission Fluid Capacity
#1504265
09/19/13 10:46 AM
09/19/13 10:46 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I just installed a TF2 kit in my SB 727 and am in the process of filling it back up. I did not drain the torque convertor. How much fluid should this take. I filled it with 5 quarts already. I've checked it after each 1/2 quart for the last 2 now and the mark hasn't moved. ![](/ubbthreads/images/graemlins/shruggy.gif) It's still at the "add a pint" mark. How much fluid should this take? Trans pan and convertor are stock. I'm checking hot and running in park as the TF2 instruction said.
Re: Transmission Fluid Capacity
[Re: buildanother]
#1504268
09/19/13 11:54 AM
09/19/13 11:54 AM
mopowers
Sac, CA
Got it running and in neutral, it may not take much more at all.
I've been checking it running in Park. I believe that what the TF-2 shift kit instruction said.
[Re: kloyiod]
#1504269
09/19/13 11:54 AM
09/19/13 11:54 AM
mopowers
Sac, CA
19 1/2 pints, thats 9 3/4 quarts for those that don't know how many pints to a quart.
Is that 9 3/4 with or without the converter?
[Re: mopowers]
#1504270
09/19/13 01:27 PM
09/19/13 01:27 PM
Posts: 1,822 Colorado
denfireguy
Colorado
If it were me, I would check it in neutral. Part of the shift kit is to allow the pump to work in Park as well as Neutral. Since I just made that modification, I just want to make sure everything is working before I would trust the pump is actually working in Park. Just me, I always worry about whether my work was good or not. Some day I will have self confidence, but until that day, call me skeptical. ![](/ubbthreads/images/graemlins/blush.gif) Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1504271
09/19/13 02:12 PM
09/19/13 02:12 PM
mopowers
Sac, CA
I thought I recall the instructions saying that you can no longer check it in neutral. I'll have to look when I get home.
