Re: quadrajet help
[Re: mopower440]
#1504047
09/19/13 12:57 AM
09/19/13 12:57 AM
Posts: 654 MN
astrobuf
MN
You have an internal fuel leak. Is the float too high and your internally spilling gas? A misplaced gasket etc? Astrobuf ![](/ubbthreads/images/graemlins/beer.gif)
So, are you really a Rocket Scientist?
Re: quadrajet help
[Re: mopower440]
#1504048
09/19/13 01:39 AM
09/19/13 01:39 AM
RapidRobert
If the carb is OK on the inside as Buf said then the initial is too low
Re: quadrajet help
[Re: RapidRobert]
#1504049
09/19/13 11:15 AM
09/19/13 11:15 AM
Posts: 15,487 Florida
scratchnfotraction
![](/ubbthreads/images/graemlins/iagree.gif) I just had the same problem, when I opened up the q-jet,one of the needles was bent 90* and not going thru the jet. I must have done that 4 yrs ago when I put a new kit in it, then stored it on the self till last week. how much slop does the primary throttle shaft have? that can be a vac leak/tuning mightmare. when trying to adjust the idle mixture on a q-jet. I set the timing with a vac gauge to get highest vac reading, then back off 1 full # and then adjust the idle screws to get highest vac reading while in gear.
Re: quadrajet help
[Re: scratchnfotraction]
#1504050
09/20/13 09:56 PM
09/20/13 09:56 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
what is the part number from the carb? And what is the application
is there an idle solenoid of just the base adjustment screw?
float levels are super important as stated above. Also - there is a power piston in the front center of the carb - is it seating correctly? Kind of is like a power valve on a Holley.
Did you use the same thick gasket under the carb, or did you replace it? need to be sure it is exactly the same in shape all the way around and particularly up front by the primary bores.
bill
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: quadrajet help
[Re: 67_Satellite]
#1504052
09/21/13 09:28 PM
09/21/13 09:28 PM
72ls5fla
Florida, US
still have to epoxy -
you are 100% correct about the the fuel bleed down.
the two wells under the jets/metering rods are one source, the other leak will come from up front where the fuel inlet is.
whats bad is not all epoxies hold up well to ethanol. particularly higher concentrations over 10% for extended periods of time.
I had to send my carb back to the restorer to have him use a marine grade epoxy.
