Carb tuning question
#1503384
09/17/13 10:19 PM
09/17/13 10:19 PM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
I installed a milder cam and am in the process of retuning my carb. Previous cam was a MP 509 hyd and I installed a Lunati 60303 hyd. With the new cam I can't get the car to idle under 1000rpm and that is with closing down the butterflies past baseline settings. If I screw the IMS screws in to get the idle down and the AFR cleaner they are 3/4 turn out and I get an off idle stumble. I am working with a mighty demon 825 by the way.
I had previously drilled a .091" hole in each of the primary throttle blades to get the carb to idle right with the 509 cam. Could these holes now be my problem?
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: Carb tuning question
[Re: Locomotion]
#1503386
09/17/13 10:50 PM
09/17/13 10:50 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I have 12-13"hg vac at idle now compared to 6-7" with the old cam. I have a 6.5 pv installed now with a 9.5 and 10.5 on the way. My timing is 25 I initial and 36 total.
I notice hat when I adjust the primary iss it has little effect on the idle speed but when I make a small adjustment to the secondary iss it has a much more dramatic effect on the idle speed. That is what has me thinking the drilled primary blades are my problem. I have replacement primary throttle plates but can't get he darn screws out to replace them. What's the secret to getting those screws out? Looks like he factory mashes the tip on them so they won't back out and drop in engine.
[Re: @#$%&*!]
#1503389
09/18/13 10:14 AM
09/18/13 10:14 AM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Take a small file to the screw ends where they were bradded over. It helps if you wire the throttle open and then put the throttle plate in a vice with some wood or soft jaws.
[Re: oldtimer5151]
#1503392
09/18/13 09:14 PM
09/18/13 09:14 PM
tywebb2
super gas
super gas
Jarrettsville, MD
My transitions were set at .020" (small square on the primary) and barely showing on the secondary. I think the stumble may have had more to do with the IMS screws being in too far (only 3/4 turn out)?
Anyway... I decided to install new primary throttle plates without the holes. Was able to file the ends off the screws and get them to back out tonight. Waiting for some new screws to come so will have to wait to see if it has any effect on the carb tuning or not.
I had thought about backing off the initial timing a bit but then thought guys run with distributors locked out without any trouble. How can this be? Are they just large long duration cams that need this?
