Re: 2011 challenger exhaust "drone"
[Re: 71birdJ68]
#1503223
09/18/13 11:19 PM
09/18/13 11:19 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
check out solo performance's cat back
or on the cheap, keep the resonators in the back, and eliminate the mufflers under the floor....
[Re: slantzilla]
#1503225
09/19/13 11:35 AM
09/19/13 11:35 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Is it the one that cuts back to 4 cyls at cruse? I sons Magnum did that, and it would drive you crazy.Sounds great when running 8. I also talked to a man that had the same problem.
That was the first thing I thought of. Can't you go in the dash menu and turn it off?
The droan is very common with the MDS equipped cars when replacing/modifying factory exhaust.
The better $$$ aftermarket Cat Back systems usually have mufflers and rear resonators to eliminate the droan problem.
I believe it takes an aftermarket programmer, (like a Predator), to turn the MDS off.
[Re: KillerBee]
#1503226
09/19/13 11:42 AM
09/19/13 11:42 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
When you use autostick MDS is off but you can still have drone at certain speeds. Borla and Mopar sell the $$$ system that has no drone.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
