Header tether rule update..
#1502988
09/17/13 03:24 AM
09/17/13 03:24 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
For thos who have not heard the NHRA has ammended it's tehter rule for 2014. Here is the latest version of the rule. Basically if you dont want to run one of the NHRA approved tethers from the two approved vendors you can simply have a 1/2" stitch weld to each primary tube. I am sure there will be more changes as it gets closer to next year. Here is the link http://www.nhraracer.com/content/general.asp?articleid=56756&zoneid=132
Re: Header tether rule update..
[Re: rickraw]
#1502994
09/17/13 05:42 PM
09/17/13 05:42 PM
Al_Alguire
Las Vegas
Yes tabs and bolts as of 2014 will NOT be legal. You will either need one of the two excessively priced NHRA approved tether systems or as amended a one inch stich weld on ALL the primary tubes. Results of racers NOT doing maintenance on their cars and causing injury to others.
I have tabs, bolts and mufflers and still have to conform to the new rule.
[Re: Al_Alguire]
#1502995
09/17/13 05:52 PM
09/17/13 05:52 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Lest see, by the time I get my ride back out. Have no idea when that will be I'll need New belts (6 passes) New helmet (hardly worn, like new) New jacket (never been washed) Diaper Header restraints What else am I missing?????
[Re: tboomer]
#1502999
09/17/13 06:20 PM
09/17/13 06:20 PM
roadhazard
Akron, Ohio U.S.A.
A buttload of cash!!
And a jar of that special petroleum jelly
I'm all for being safe and the safety of everyone else. If they are going to check for tethers on my headers, why can't they just look to make sure my tabs are bolted properly?
Maybe they should have sealed lug nuts
Once they are torqued you can not remove them without the express written permission of the NHRA
[Re: John Burdine]
#1503002
09/17/13 06:42 PM
09/17/13 06:42 PM
Posts: 20,191 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is this just NHRA or did IHRA mandate this too?
[Re: Al_Alguire]
#1503003
09/17/13 07:11 PM
09/17/13 07:11 PM
Posts: 5,875 communist bloc of new jersey
jamesc
What's the ruling if the car has pipes and mufflers on it?
The way the rule still currently reads is if you have a slip on collector you have to either stitch weld or purchase the approved tethers. Since I have mufflers that was why I asked and that was the answer I was given last week.
yea cause we all know welds on headers never crack
nhra...gotta love em
[Re: roadhazard]
#1503006
09/17/13 09:38 PM
09/17/13 09:38 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
can any one say even more kick backs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1503007
09/17/13 09:41 PM
09/17/13 09:41 PM
dusturbd340W5
Kissimmee Fl.
I have been depressed for over 2 years that I had to sell my ride BUT the more crap that comes out like this the better I feel about it. When I do get to go back to racing it will most likely be on a bike very little safety stuff there to worry about. no belt issue no net no ect ect.
