Broke a G3 Hemi crank..can I salvage the 6.1 block?
#1502719
09/16/13 07:43 PM
09/16/13 07:43 PM
Posts: 833 MN
hemidup
MN
The front journal gave up the ghost. Was a Callis 4.05" stroker crank and I take it it didn't like the additional strain of an F1R cog drive blower hanging off the front. Anyways the front main cap was junk and when the front cap was pulled off noticed that there was a hair line crack on both sides of the block from the main cap mating surface bolt hole and worked its way to the upper shell main bearing surface. Any way to fix it or is the block just a paper weight?
Jerry Williams.
Re: Broke a G3 Hemi crank..can I salvage the 6.1 block?
[Re: hemidup]
#1502722
09/16/13 07:56 PM
09/16/13 07:56 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Boat anchor,,,or send it to me and I will have a set of 'book ends' to hold G3 shop manuals. That sucks Jerry.
If you like drag racing, support your local track.
