http://www.dodgecharger.com/forum/index.php?topic=10449.0;wap2Engine 1971-92 360 LA 1993-03 Magnum 5.9L
Piston 584 grams 470 grams
Piston Pin 154.6 grams 134 grams
Connecting rod small end 239 grams 225 grams
Connecting rod big end 519 grams 519 grams
Ring Set 56.6 grams 40 grams
Rod Bearing 47.6 grams 47.6 grams
Reciprocating Weight 1,034.2 grams 869 grams
Rotating Weight 566.6 grams 566.6 grams
Weight per Cylinder 1,600.8 grams 1,435.6 grams
Total Bob Weight 2,167.4 grams 2,002.2 grams
Dunno what your cutoff is for a rebalance, but here's the numbers. I know it's for a 360, all I could handily find.
