Page 4 of 5 1 2 3 4 5
Re: Ok so I broke a rod ! head off more pics [Re: dustergirl340] #1502655
09/17/13 10:41 PM
09/17/13 10:41 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
My wife said.. when you break them you make sure no one else is ever going to use it again..good job ! LOL that is after she cry'ed
Re: Ok so I broke a rod ! head off more pics [Re: VernMotor] #1502656
09/18/13 12:50 AM
09/18/13 12:50 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Jamie"Grenade"Vernon has a nice ring to it.Hang in there.
Re: Ok so I broke a rod ! head off more pics [Re: VernMotor] #1502657
09/18/13 01:46 AM
09/18/13 01:46 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sooooo, have you broken the news to Terry yet?
Re: Ok so I broke a rod ! [Re: Twostick] #1502658
09/18/13 03:10 AM
09/18/13 03:10 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
So what broke first, the piston, the rod or might it have seized a pin?
Kevin
My initial thought was maybe the pin seized, as I've heard that aftermarket rods can be too tight on the small end. The thing I've never understand about a seized pin is why would it matter if the pin seized in the rod if its full floating? It would need to seize in the rod and the piston, would it not?
Re: Ok so I broke a rod ! [Re: GTX MATT] #1502659
09/18/13 11:23 AM
09/18/13 11:23 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I just built a 440 with Scat rods. Standard rod bolt not the ARP 2000 bolts. It ran 11.00's the first night out shifting at 6400 but when I went to check the timing the next day it had a noise coming from the bottom of the engine. When I pulled the pan I found one of the rod bolts hadn't been torqued and had backed out about 1/4". It was hitting the windage tray. The rod cap and opposite bolt where bent up. Amazingly the crank was fine and I replaced the rod and bearing and went 10.90's the next weekend.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Ok so I broke a rod ! [Re: d7cook] #1502660
09/18/13 12:06 PM
09/18/13 12:06 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I do believe i've seen enough engine carnage pictures for the week.
72 Plymouth Roadrunner 11.08@123.25
Re: Ok so I broke a rod ! [Re: n20mstr] #1502661
09/18/13 06:00 PM
09/18/13 06:00 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
im no expert....
BUT i would speculate that the cyl wall cracked....
filled that hole with some water and...then your rod broke
Re: Ok so I broke a rod ! head off more pics [Re: dustergirl340] #1502662
09/19/13 12:02 PM
09/19/13 12:02 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
I have never seen an oil ring wrapped around valves before.
Hell, if you're gonna break, might as well make it memorable.
I think he installed it wrong.. and one question did you let brian spring touch the car in anyway??
But that really sucks to hear and see..
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Ok so I broke a rod ! head off more pics [Re: kissmyaspen] #1502663
09/19/13 02:56 PM
09/19/13 02:56 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
HA HA LMAO I did park next to him !
Re: Ok so I broke a rod ! head off more pics [Re: VernMotor] #1502664
09/19/13 03:02 PM
09/19/13 03:02 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats cruel.
Re: Ok so I broke a rod ! head off more pics [Re: dartman366] #1502665
09/19/13 03:10 PM
09/19/13 03:10 PM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Re: Ok so I broke a rod ! head off more pics [Re: 360904] #1502666
09/19/13 03:41 PM
09/19/13 03:41 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
VERN DO NOT LOOK ANY FURTHER ITS NOT A ROD ITS NOT BEARINGS ITS NOT ENGINE BUILDER ITS A LOOSE CONVERTER BOLT THAT HIT THE CAM SECTION IN THE REAR OF THE BLOCK AND KABOOM-WHEN I SAW THOSE PICTURES I GOT FLASH BACKS BEEN THERE DONE THAT I FEEL YOUR PAIN
Re: Ok so I broke a rod ! head off more pics [Re: cesar perez] #1502667
09/21/13 06:19 AM
09/21/13 06:19 AM
Sydney NSW
Rodsports Offline
Rodsports  Offline
Sydney NSW
Vern,
If nothing else, it is SPECTACULAR to look at. But I agree, ouch.....
Re: Ok so I broke a rod ! head off more pics [Re: Rodsports] #1502668
09/21/13 08:55 AM
09/21/13 08:55 AM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
What size is the wrist pin? (1.094 or .990)? Does Eagle use the same forging for both pins and bush them differently?
Re: Ok so I broke a rod ! head off more pics [Re: Moore & Moore] #1502669
09/21/13 11:15 AM
09/21/13 11:15 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Vern, is that an I-beam rod with a pressed pin? I use Eagle h-beam with 990 floating pin and my car goes thru the traps at 7200 and I have 390 runs on the engine.
Re: Ok so I broke a rod ! head off more pics [Re: cgall] #1502670
09/21/13 12:00 PM
09/21/13 12:00 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Eagle h-beam 1.094 pin floating pin. Jack I do not know ?
Re: Ok so I broke a rod ! [Re: VernMotor] #1502671
09/22/13 12:44 AM
09/22/13 12:44 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I like that price sheet
I need a few things on that list.
Re: Ok so I broke a rod !Oil Pan off New pics !!! [Re: VernMotor] #1502672
09/22/13 07:26 PM
09/22/13 07:26 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
New pics add'ed to the first post !
Re: Ok so I broke a rod !Oil Pan off New pics !!! [Re: VernMotor] #1502673
09/22/13 11:13 PM
09/22/13 11:13 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
At that point I would cut my losses with that build and go for something different.
How about a small block, with a nice set of twin turbos and fuel injection???
Or you can buy my 540 off me and ill build the TTSB
Sorry to see that, I hate seeing other peoples carnage. For me, its just a chance for a new beginning. I get so side tracked that by the time I am close to finishing a project I am ready for something new any how.
Re: Ok so I broke a rod !Oil Pan off New pics !!! [Re: 8urvette] #1502674
09/22/13 11:36 PM
09/22/13 11:36 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i know there are tons of chinese cranks and rods in use out there. personally i'm just scared of them, the rods especially. not that premium parts can't/don't fail but i would think using a quality usa forged/billet/machined rod would be money well spent when you consider all the collateral damage that can occur when a rod fails. problem is there aren't a lot of choices for usa made rods and while the machine work that some are doing in the us should be superior you're still working with an imported blank
personally the only chinese part i have is a crank i've yet to use. the rods i have/used are BME, manley and oliver
Vern you didn't play around, that's a real mess you made there. was just looking at a friends roundy engine the other day that he did something similar. callies ultra lite crank, oliver rods the works. didn't get real far into it but looks like a bearing failed and the engine had been recently gone through. no signs of other oiling distress just a bearing that failed and he ran it till it pitched the rod
