Opinions on 3 point seat belt kit in 70 b-body? #1502482
09/16/13 03:09 PM
09/16/13 03:09 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
My factory belts are a bit crusty and have faded in many places. While looking at replacement belts, I came across a 3 point belt kit that caught my attention. My car is a driver, so I do not think this is going to hurt the value of my ride and I will fell alot better if my wife or daughter is in the passenger seat with a shoulder belt. Anyone use a kit before? Known issues?
I am looking at this one:
http://www.seatbeltsplus.com/product/3-6870-B-Body2BU.html
--Jim
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: BPBP440] #1502483
09/16/13 03:25 PM
09/16/13 03:25 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I used Andover Restraints in my 'Cuda. A major improvement over the factory belts. One possible problem you may have is that my car is a '72 model and they had 3 point belts from the factory. The factory design left a lot to be desired since you couldn't move once you were buckled in. The Andovers use the factory bolts and locations, but they have inertia reals for the shoulder straps so you can move around just like in most cars today. Your car being a '70 model may not have the factory mount in the roof for the shoulder belt. I am not sure just when the factory went to the 3 point design. If you don't have factory bolt locations something will have to be fabricated. You can find out more about the Andovers at www.andoauto.com/retrofit.htm
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: 5spdcuda] #1502484
09/16/13 03:40 PM
09/16/13 03:40 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
HE WILLHAVE THE MOUNTS IN THE roof. 1970 cars hd factory shoulder belts
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: BPBP440] #1502485
09/16/13 03:51 PM
09/16/13 03:51 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Another source for belts:
Juliano's
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: 05dakota] #1502486
09/16/13 03:52 PM
09/16/13 03:52 PM
BPBP440 Offline OP
BPBP440  Offline OP
Currently I only have lap belts, so it sounds like at minumum I could easily go to the stock shoulder belt set-up.
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: BPBP440] #1502487
09/16/13 04:08 PM
09/16/13 04:08 PM
Your car had shoulder belts when new. Lots of aftermarket set-ups with and without shoulder retractors available to mount in the factory locations. Both Seatbeltsplus and Juliano's have some good quality sets.
Re: Opinions on 3 point seat belt kit in 70 b-body? [Re: nomore65BelvJim] #1502488
09/16/13 04:11 PM
09/16/13 04:11 PM
BPBP440 Offline OP
BPBP440  Offline OP
Thanks for the info and the the vendor recommendations. Greatly appreciated.
