426 Wedge Motor ID Pad. #1501979
09/15/13 08:31 PM
09/15/13 08:31 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Looked at a car today that has a 1965 426 Wedge motor. ID pad shows:
A426 then a Maltese Cross
5 21 2
All these in normal font I'm used to seeing on my 66-74 cars. Then there is an HP in Max wedge size font between the A426 and the build date. Any thoughts from the 426 wedge experts? Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 426 Wedge Motor ID Pad. [Re: TimS] #1501980
09/15/13 09:32 PM
09/15/13 09:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pic's worth a thousand words but so far it sounds typical of a 65 426S Wedge.
Re: 426 Wedge Motor ID Pad. [Re: ScottSmith_Harms] #1501981
09/15/13 09:51 PM
09/15/13 09:51 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
What little I know that's what it appears to me as well. It has a single Carter 4 bbl on it with 6 bolt valve covers instead of the Max Wedge 4 bolt. The HP in larger font throws me though. The HP has been hit unevenly as well. Deeper at the bottom than the top. Like it was done after the fact.
Re: 426 Wedge Motor ID Pad. [Re: TimS] #1501982
09/15/13 09:55 PM
09/15/13 09:55 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I had a '65 Sport Fury with the 426 street wedge. My pad looked like yours sounds except I had an 'X' also (some kind of oversize or undersize, I forget which). My 'HP' stamp, IIRC, was also much larger that what was used later in the '60's. Again, IIRC the letters were easily 3/8" high.
Re: 426 Wedge Motor ID Pad. [Re: 6PakBee] #1501983
09/15/13 10:05 PM
09/15/13 10:05 PM
Alabama
BigMoneyLewis Offline
Alabama
Most Max wedges will be stamped MP (Maximum performance) not HP.
An HP stamp is a typical 365 horse .
Greg
gregward@mchsi.com phone 256-852-0955
Re: 426 Wedge Motor ID Pad. [Re: 6PakBee] #1501984
09/15/13 10:31 PM
09/15/13 10:31 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
So the HP is a factory stamp even with the larger font?
Re: 426 Wedge Motor ID Pad. [Re: TimS] #1501985
09/15/13 10:44 PM
09/15/13 10:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They didn't make a non HP 426 Street Wedge so the HP is likely original. If you want a more solid evaluation post a clear pic
Re: 426 Wedge Motor ID Pad. [Re: TimS] #1501986
09/16/13 09:58 AM
09/16/13 09:58 AM
North Dakota
North Dakota
All I can say is I bought the car in 1973 before all the "numbers games" started so I've always assumed it was original. I thought the stamp font was odd but never pursued it. Remember, at that time Al Gore hadn't invented the internet yet and research was somewhat difficult. I sold the shortblock to someone in Denver in about 1985 so I don't have anything that I can show you now. That's the best I can do. It was a nice motor. Had a set of reworked rods and a set of Jahns forged pistons in it.
Re: 426 Wedge Motor ID Pad. [Re: 6PakBee] #1501987
09/16/13 12:54 PM
09/16/13 12:54 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
You would think it was factory. Makes sense.
Re: 426 Wedge Motor ID Pad. [Re: TimS] #1501988
09/16/13 10:00 PM
09/16/13 10:00 PM
Neenah,Wi
rod440 Offline
rod440  Offline
Neenah,Wi
The 413 in my '65 300L has the large HP stamped in the pad & it is the original engine.I would think the large HP would be correct for the 426 street wedge also.
Re: 426 Wedge Motor ID Pad. [Re: rod440] #1501989
09/17/13 07:18 AM
09/17/13 07:18 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the info. My 35 plus years of restoring Mopars has been predominately on 68-74 B and E bodies so this research on the 62 Sport Fury has been different to say the least, along with the 65 Street wedge that's in it.
Re: 426 Wedge Motor ID Pad. [Re: BigMoneyLewis] #1501990
09/19/13 12:53 AM
09/19/13 12:53 AM
Edmonton alberta Canada
mr. 63plymouth Offline
Greg
Actually ALL 1962 Maximum Performance dodge and plymouth's had HP on the ID pad! And HP-HC for high compression deals
